Auto Headlights and Rain sensor retrofit
carbon_gecko
texas
2016 GOLf tsi 'S'
OK: when you install 5Q0-955-547 module, perhaps these VCDS screens will be useful?
Don
okay so I installed the 947-B and cleared the errors...sadly they came right back and i coded it to 00A8DD and still turn signal faults no comms with the RLHS and light switch signal fail. i will trouble shoot tomorrow.
DV52
Australia
@carbon_gecko : Bummer. If you can't fix - post-up a new copy of the latest auto-scan
Don
carbon_gecko
texas
2016 GOLf tsi 'S'
Don
DV52,
Nope couldn't fix it. i have tried checking my connections and all seems right the only possible issue i see is the mini tap i have going to fuse 8c (a 10A i checked the direction of the fuse tap and its draw 12v ) is there a different location this has to go to or the incorrect resistance? i also tried to change long coding one at a time to see if anything cleared but nothing did. i did notice that for the RLHS long coding i receive an error for any byte other than 0, and no information loads for each bit (picture posted )
  • Log-MINE-3VW217AU8GM034482-92067km-57207mi.txt
DV52
Australia
@carbon_gecko : hmm.......... clearly the BCM isn't communicating with the RLHS.
Here's the wiring diagram for the 5Q0-955-547 (J519 is the BCM):
Note: the wiring is different to the 4 x pin sensor that I included on post #20 in this thread - the 955-547 is a very simple 3 x pin device. Check that you have volts on pin#1 (red/white wire) and that pin#2 (brown wire) is connected to earth (these tests should be done at the sensor housing pins).
If both these pins check-out OK, then the problem has to be the LIN wire at pin #3 (purple/white wire) - which is the actual comms wire for data exchange. As shown, this connects to pin#28 on socket C on the BCM -since you retrofitted the sensor, I assume that you added this wire as part of the install process. Check that the connection was made to the correct pin/socket at the BCM and also confirm continuity of the connection back to the RHLS pin.
If all these checks are OK - I suspect a faulty sensor - may be?
Don
carbon_gecko
texas
2016 GOLf tsi 'S'
Don
so no joy, checked power at the sensor: 12.24v, checked to ensure BCM c28 too: yup, verified the BCM actually has a c28 pin: yup, here is a video of the lightswitch in use. notice in auto the halogens are on due to the light sensor working even though the error persists. Also the normal turn signal flash compared to the double speed indicator.
DV52
Australia
@carbon_geko : Strange?
Please answer ALL these questions:
  1. Does the rain sensing wiper work on the new RHLS?
  2. Does the turn-signal error message appear also when the right-side blinker is operated?
  3. Have you done anything to the left/right side-maker lights?
  4. How many wires are terminated in the connector on the back of the light switch?
Please make an adaptation channel map of the BCM and post-up. When you get to the admap dialogue box - set it up as follows:
And regarding the humidity side of the RHLS, here's how to register the new sensor in the Auto HVAC module @ address hex08:
Don
carbon_gecko
texas
2016 GOLf tsi 'S'
Don
i believe it does but i dont know the specific speed at which it should sweep (i set the interval to minimum and covered the sensor and each time i did that it would sweep. yes both left and right side error. i have done fog lights on for turn signal coding but that's it. i have 9 wires going into the light switch. yes i have humidity sensor installed selected in control unit 08. i will go get that adaption map in a moment. it will not let me upload the excel file as an attach file.
carbon_gecko
texas
2016 GOLf tsi 'S'
since it wont let me upload a .csv file here is the copy and paste:
;SW:5Q0-937-087-AA HW:5Q0-937-087-AA --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162Coding:0000184240C196F869E4400000040F001008000000000000000000000000
;EV_BodyContrModul1UDSBosc
15002​
EV_BCMBOSCH_015.rod
;Saturday
30​
January
2021​
;VCDS Version: Release 20.12.0 (x64) Data version: 20201125 DS322.1
;VCID: 7AADF59C2C5353AB3D6-802E
IDE00001-ENG99061-Production mode-Access controlnot active
3​
IDE00001-ENG115730-Production mode-Exterior lightingnot active
3​
IDE00001-ENG116710-Production mode-Frontwischer deaktivierennot active
3​
IDE00001-ENG112304-Production mode-Heckwischernot active
3​
IDE00001-ENG98647-Production mode-Interior lightsnot active
3​
IDE00001-ENG115729-Production mode-Scheinwerferreinigungnot active
3​
IDE00001-ENG115731-Production mode-Virtuel_pedalnot active
3​
IDE00002-Transport modenot active
1​
IDE00820-Activating and deactivating all development messagesnot active
1​
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRAnot active
12​
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
0​
12​
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogrammactive
12​
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlaufactive
12​
IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtaupositionnot active
12​
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltungactive
12​
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischernot active
12​
IDE01268-ENG115771-Windshield wiper-Regensensor aktivierenDeactivating
12​
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangelnot active
12​
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit0 ms
12​
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit0 ms
12​
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit0 ms
12​
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit0 ms
12​
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit0 ms
12​
IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschennot active
12​
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenzactive
12​
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Statusnot active
12​
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierungnot active
12​
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant
0​
12​
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaubenot active
12​
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 ausnot active
12​
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaubenot active
12​
IDE01550-Service position170.49 °
2​
IDE02152-Characteristics in production mode2000 ms
4​
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during lockingDELAY
4​
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegelnnot active
4​
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung globalactive
4​
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhornactive
4​
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegelnactive
4​
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhornshort
4​
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldungactive
4​
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchtenot active
4​
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessenactive
4​
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehlnot active
4​
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehlnot active
4​
IDE02332-Deactivate production mode
0​
3​
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischenactive
8​
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischennot active
8​
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 10 s
8​
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 20.0 s
8​
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlaufnot active
8​
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparkennot active
8​
IDE02711-ENG114946-Rear wiper-Komfortwischen Heckactive
8​
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 15 s
8​
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 23 s
8​
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik7 s
8​
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall7 s
8​
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HWactive
8​
IDE02711-ENG116691-Rear wiper-Traenenwischen Heckactive
8​
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum
100%​
8​
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer
80%​
8​
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn
80%​
8​
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierungnot enabled
8​
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafelnot installed
8​
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafelnot installed
8​
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset-63.75 °
14​
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit50.00 %/s
14​
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrtboth sides
14​
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold0.00 km/h
14​
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur100.00 °C
14​
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur95.00 °C
14​
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel120 °
14​
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur80.00 °C
14​
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel180 °
14​
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold40.00 km/h
14​
IDE03638-ENG116674-Stationary cornering lamp-VorschriftECE R119
14​
IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinkenactive
8​
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaengerseparte
8​
IDE04923-ENG115774-Turn signal control-Komfortblinkenactive
8​
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen
3​
8​
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer BlinkerMFG
8​
IDE04923-ENG116588-Turn signal control-Sonderfunktionennot enabled
8​
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelungnot active
8​
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung AktivierungAlways active
8​
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor
0.1​
8​
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert
10.00%​
8​
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze350 km/h
14​
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze350 km/h
14​
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslichtintegriert in Suchbeleuchtung
14​
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglichactive
14​
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhaltenklemmenabhaengig
14​
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHOMenuesteuerung Zeit aktivieren
14​
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit0 km/h
14​
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviertnot active
14​
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktionnot active
14​
IDE04924-ENG126816-Driving light and parking light-Standlicht ausactive
14​
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklichtnot active
14​
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlichtnot active
14​
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitierenlimitieren
14​
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht15 min
14​
IDE04926-ENG115656-Comfort illumination-Coming Home LeuchtenLow beam
8​
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatusnot installed
8​
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignisignition
8​
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung0 lx
8​
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung0 lx
8​
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatusnot enabled
8​
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghomenot active
8​
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAPnot active
8​
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellungnot active
8​
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAPnot active
8​
IDE04927-IDE01446-Window heater-Running time of heated front window240 s
8​
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung35.00 °C
8​
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung35.00 °C
8​
IDE04927-ENG126845-Window heater-FSH Automatikactive
8​
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert320 s
8​
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSHactive
8​
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSHactive
8​
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhornactive
4​
IDE04928-ENG115864-Anti-theft protection-Alarmsignalfrequency modulated
4​
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerungnot active
4​
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modusnot active
4​
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl1 Alarm
4​
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebelnot active
4​
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarmkeine verzoegerung
4​
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heckactive
8​
IDE05142-ENG116621-Access control-automatisches Entriegelnactive
8​
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeitactive
8​
IDE05142-ENG116706-Access control-Autounlock NARactive
8​
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFBnot active
8​
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigungnot active
8​
IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_externnot active
8​
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstasteractive
8​
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckelsnot active
8​
IDE05142-ENG115722-Access control-Electrical rear lidnot active
8​
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgangnot active
8​
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Einnot active
8​
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktasternot active
8​
IDE05142-ENG115754-Access control-Funk bei Klemme 15 einnot active
8​
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelungnot active
8​
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperrenactive
8​
IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerungnot active
8​
IDE05142-ENG133388-Access control-LS_Taster_Togglefunktionnot active
8​
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelungactive
8​
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlockadjustable
8​
IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster0.00 s
8​
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegeltnot active
8​
IDE05142-ENG115755-Access control-Notschließfunktionactive
8​
IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessungnot active
8​
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelungnot active
8​
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappenot active
8​
IDE05142-ENG125652-Access control-Servoheck SchlossansteuerungAlways
8​
IDE05142-ENG126838-Access control-Softtouch-Betaetigung sendenAlways
8​
IDE05142-ENG115758-Access control-Valet Parkingactive
8​
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabenot active
8​
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BTnot active
8​
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuernot active
8​
IDE05142-ENG133390-Access control-Wiederverriegelung_LaderaumFreigabe_Softtouch
8​
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckelactive
8​
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfennot active
8​
IDE05142-ENG116623-Access control-ZV TuerentriegelungEinzeltuerentriegelung
8​
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrashnot active
8​
IDE05143-MAS02985-Writing parameter-Value
130​
5​
IDE05143-MAS04381-Writing parameter-Parameter addressFE 00 00
5​
IDE05144-Read parameter addressFE 00 00
3​
IDE05145-ENG115874-Light configuration-BAP Bitposition 0
34​
560​
IDE05145-ENG115893-Light configuration-BAP Bitposition 13E
560​
IDE05145-ENG116063-Light configuration-BAP Bitposition 10
0​
560​
IDE05145-ENG116082-Light configuration-BAP Bitposition 11
0​
560​
IDE05145-ENG116101-Light configuration-BAP Bitposition 12
38​
560​
IDE05145-ENG116120-Light configuration-BAP Bitposition 13
42​
560​
IDE05145-ENG116139-Light configuration-BAP Bitposition 14
0​
560​
IDE05145-ENG116158-Light configuration-BAP Bitposition 15
0​
560​
IDE05145-ENG116177-Light configuration-BAP Bitposition 16
0​
560​
IDE05145-ENG116196-Light configuration-BAP Bitposition 17
0​
560​
IDE05145-ENG116215-Light configuration-BAP Bitposition 18
0​
560​
IDE05145-ENG116234-Light configuration-BAP Bitposition 19
0​
560​
IDE05145-ENG115911-Light configuration-BAP Bitposition 2
0​
560​
IDE05145-ENG116253-Light configuration-BAP Bitposition 20
13​
560​
IDE05145-ENG116272-Light configuration-BAP Bitposition 21
23​
560​
IDE05145-ENG116291-Light configuration-BAP Bitposition 22
29​
560​
IDE05145-ENG116310-Light configuration-BAP Bitposition 230A
560​
IDE05145-ENG116329-Light configuration-BAP Bitposition 241A
560​
IDE05145-ENG116348-Light configuration-BAP Bitposition 25
28​
560​
IDE05145-ENG116367-Light configuration-BAP Bitposition 26
0​
560​
IDE05145-ENG116386-Light configuration-BAP Bitposition 27
0​
560​
IDE05145-ENG116405-Light configuration-BAP Bitposition 280B
560​
IDE05145-ENG116424-Light configuration-BAP Bitposition 291B
560​
IDE05145-ENG115930-Light configuration-BAP Bitposition 3
0​
560​
IDE05145-ENG116443-Light configuration-BAP Bitposition 30
0​
560​
IDE05145-ENG116462-Light configuration-BAP Bitposition 31
0​
560​
IDE05145-ENG116481-Light configuration-BAP Bitposition 32
0​
560​
IDE05145-ENG116500-Light configuration-BAP Bitposition 33
0​
560​
IDE05145-ENG116519-Light configuration-BAP Bitposition 34
0​
560​
IDE05145-ENG115949-Light configuration-BAP Bitposition 4
48​
560​
IDE05145-ENG115968-Light configuration-BAP Bitposition 54C
560​
IDE05145-ENG115987-Light configuration-BAP Bitposition 6
36​
560​
IDE05145-ENG116006-Light configuration-BAP Bitposition 7
40​
560​
IDE05145-ENG116025-Light configuration-BAP Bitposition 8
37​
560​
IDE05145-ENG116044-Light configuration-BAP Bitposition 9
41​
560​
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0maximize
560​
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1maximize
560​
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10maximize
560​
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11maximize
560​
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12maximize
560​
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13maximize
560​
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14maximize
560​
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15maximize
560​
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16maximize
560​
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17maximize
560​
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18maximize
560​
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19maximize
560​
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2maximize
560​
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20minimize
560​
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21minimize
560​
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22maximize
560​
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23maximize
560​
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24maximize
560​
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25maximize
560​
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26maximize
560​
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27maximize
560​
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28maximize
560​
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29maximize
560​
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3maximize
560​
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30maximize
560​
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31maximize
560​
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32maximize
560​
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33maximize
560​
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34maximize
560​
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4minimize
560​
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5minimize
560​
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6maximize
560​
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7maximize
560​
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8maximize
560​
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9maximize
560​
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0maximize
560​
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1maximize
560​
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10maximize
560​
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11maximize
560​
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12maximize
560​
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13maximize
560​
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14maximize
560​
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15maximize
560​
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16maximize
560​
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17maximize
560​
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18maximize
560​
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19maximize
560​
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2maximize
560​
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20maximize
560​
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21maximize
560​
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22maximize
560​
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23maximize
560​
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24maximize
560​
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25maximize
560​
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26maximize
560​
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27maximize
560​
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28maximize
560​
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29maximize
560​
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3maximize
560​
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30maximize
560​
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31maximize
560​
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32maximize
560​
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33maximize
560​
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34maximize
560​
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4maximize
560​
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5maximize
560​
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6maximize
560​
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7maximize
560​
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8maximize
560​
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9maximize
560​
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0maximize
560​
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1maximize
560​
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10maximize
560​
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11maximize
560​
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12maximize
560​
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13maximize
560​
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14maximize
560​
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15maximize
560​
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16maximize
560​
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17maximize
560​
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18maximize
560​
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19maximize
560​
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2minimize
560​
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20maximize
560​
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21maximize
560​
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22maximize
560​
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23maximize
560​
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24maximize
560​
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25maximize
560​
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26maximize
560​
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27maximize
560​
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28maximize
560​
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29maximize
560​
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3minimize
560​
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30maximize
560​
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31maximize
560​
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32maximize
560​
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33maximize
560​
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34maximize
560​
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4maximize
560​
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5maximize
560​
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6maximize
560​
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7maximize
560​
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8maximize
560​
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9maximize
560​
IDE05145-ENG115878-Light configuration-Dimmwert AB 0
100​
560​
IDE05145-ENG115897-Light configuration-Dimmwert AB 1
100​
560​
IDE05145-ENG116067-Light configuration-Dimmwert AB 10
0​
560​
IDE05145-ENG116086-Light configuration-Dimmwert AB 11
0​
560​
IDE05145-ENG116105-Light configuration-Dimmwert AB 12
100​
560​
IDE05145-ENG116124-Light configuration-Dimmwert AB 13
100​
560​
IDE05145-ENG116143-Light configuration-Dimmwert AB 14
0​
560​
IDE05145-ENG116162-Light configuration-Dimmwert AB 15
0​
560​
IDE05145-ENG116181-Light configuration-Dimmwert AB 16
0​
560​
IDE05145-ENG116200-Light configuration-Dimmwert AB 17
0​
560​
IDE05145-ENG116219-Light configuration-Dimmwert AB 18
0​
560​
IDE05145-ENG116238-Light configuration-Dimmwert AB 19
0​
560​
IDE05145-ENG115915-Light configuration-Dimmwert AB 2
100​
560​
IDE05145-ENG116257-Light configuration-Dimmwert AB 20
100​
560​
IDE05145-ENG116276-Light configuration-Dimmwert AB 21
100​
560​
IDE05145-ENG116295-Light configuration-Dimmwert AB 22
100​
560​
IDE05145-ENG116314-Light configuration-Dimmwert AB 23
28​
560​
IDE05145-ENG116333-Light configuration-Dimmwert AB 24
28​
560​
IDE05145-ENG116352-Light configuration-Dimmwert AB 25
100​
560​
IDE05145-ENG116371-Light configuration-Dimmwert AB 26
0​
560​
IDE05145-ENG116390-Light configuration-Dimmwert AB 27
100​
560​
IDE05145-ENG116409-Light configuration-Dimmwert AB 28
100​
560​
IDE05145-ENG116428-Light configuration-Dimmwert AB 29
100​
560​
IDE05145-ENG115934-Light configuration-Dimmwert AB 3
100​
560​
IDE05145-ENG116447-Light configuration-Dimmwert AB 30
100​
560​
IDE05145-ENG116466-Light configuration-Dimmwert AB 31
0​
560​
IDE05145-ENG116485-Light configuration-Dimmwert AB 32
0​
560​
IDE05145-ENG116504-Light configuration-Dimmwert AB 33
0​
560​
IDE05145-ENG116523-Light configuration-Dimmwert AB 34
0​
560​
IDE05145-ENG115953-Light configuration-Dimmwert AB 4
100​
560​
IDE05145-ENG115972-Light configuration-Dimmwert AB 5
100​
560​
IDE05145-ENG115991-Light configuration-Dimmwert AB 6
100​
560​
IDE05145-ENG116010-Light configuration-Dimmwert AB 7
100​
560​
IDE05145-ENG116029-Light configuration-Dimmwert AB 8
100​
560​
IDE05145-ENG116048-Light configuration-Dimmwert AB 9
100​
560​
IDE05145-ENG115882-Light configuration-Dimmwert CD 0
0​
560​
IDE05145-ENG115901-Light configuration-Dimmwert CD 1
0​
560​
IDE05145-ENG116071-Light configuration-Dimmwert CD 10
0​
560​
IDE05145-ENG116090-Light configuration-Dimmwert CD 11
0​
560​
IDE05145-ENG116109-Light configuration-Dimmwert CD 12
0​
560​
IDE05145-ENG116128-Light configuration-Dimmwert CD 13
0​
560​
IDE05145-ENG116147-Light configuration-Dimmwert CD 14
0​
560​
IDE05145-ENG116166-Light configuration-Dimmwert CD 15
0​
560​
IDE05145-ENG116185-Light configuration-Dimmwert CD 16
0​
560​
IDE05145-ENG116204-Light configuration-Dimmwert CD 17
0​
560​
IDE05145-ENG116223-Light configuration-Dimmwert CD 18
0​
560​
IDE05145-ENG116242-Light configuration-Dimmwert CD 19
0​
560​
IDE05145-ENG115919-Light configuration-Dimmwert CD 2
0​
560​
IDE05145-ENG116261-Light configuration-Dimmwert CD 20
0​
560​
IDE05145-ENG116280-Light configuration-Dimmwert CD 21
0​
560​
IDE05145-ENG116299-Light configuration-Dimmwert CD 22
0​
560​
IDE05145-ENG116318-Light configuration-Dimmwert CD 23
0​
560​
IDE05145-ENG116337-Light configuration-Dimmwert CD 24
0​
560​
IDE05145-ENG116356-Light configuration-Dimmwert CD 25
0​
560​
IDE05145-ENG116375-Light configuration-Dimmwert CD 26
0​
560​
IDE05145-ENG116394-Light configuration-Dimmwert CD 27
100​
560​
IDE05145-ENG116413-Light configuration-Dimmwert CD 28
0​
560​
IDE05145-ENG116432-Light configuration-Dimmwert CD 29
0​
560​
IDE05145-ENG115938-Light configuration-Dimmwert CD 3
0​
560​
IDE05145-ENG116451-Light configuration-Dimmwert CD 30
100​
560​
IDE05145-ENG116470-Light configuration-Dimmwert CD 31
0​
560​
IDE05145-ENG116489-Light configuration-Dimmwert CD 32
0​
560​
IDE05145-ENG116508-Light configuration-Dimmwert CD 33
0​
560​
IDE05145-ENG116527-Light configuration-Dimmwert CD 34
0​
560​
IDE05145-ENG115957-Light configuration-Dimmwert CD 4
0​
560​
IDE05145-ENG115976-Light configuration-Dimmwert CD 5
0​
560​
IDE05145-ENG115995-Light configuration-Dimmwert CD 6
0​
560​
IDE05145-ENG116014-Light configuration-Dimmwert CD 7
0​
560​
IDE05145-ENG116033-Light configuration-Dimmwert CD 8
0​
560​
IDE05145-ENG116052-Light configuration-Dimmwert CD 9
0​
560​
IDE05145-ENG115886-Light configuration-Dimmwert EF 0
0​
560​
IDE05145-ENG115905-Light configuration-Dimmwert EF 1
0​
560​
IDE05145-ENG116075-Light configuration-Dimmwert EF 10
0​
560​
IDE05145-ENG116094-Light configuration-Dimmwert EF 11
0​
560​
IDE05145-ENG116113-Light configuration-Dimmwert EF 12
100​
560​
IDE05145-ENG116132-Light configuration-Dimmwert EF 13
100​
560​
IDE05145-ENG116151-Light configuration-Dimmwert EF 14
0​
560​
IDE05145-ENG116170-Light configuration-Dimmwert EF 15
0​
560​
IDE05145-ENG116189-Light configuration-Dimmwert EF 16
0​
560​
IDE05145-ENG116208-Light configuration-Dimmwert EF 17
0​
560​
IDE05145-ENG116227-Light configuration-Dimmwert EF 18
0​
560​
IDE05145-ENG116246-Light configuration-Dimmwert EF 19
0​
560​
IDE05145-ENG115923-Light configuration-Dimmwert EF 2
0​
560​
IDE05145-ENG116265-Light configuration-Dimmwert EF 20
28​
560​
IDE05145-ENG116284-Light configuration-Dimmwert EF 21
28​
560​
IDE05145-ENG116303-Light configuration-Dimmwert EF 22
0​
560​
IDE05145-ENG116322-Light configuration-Dimmwert EF 23
0​
560​
IDE05145-ENG116341-Light configuration-Dimmwert EF 24
0​
560​
IDE05145-ENG116360-Light configuration-Dimmwert EF 25
0​
560​
IDE05145-ENG116379-Light configuration-Dimmwert EF 26
0​
560​
IDE05145-ENG116398-Light configuration-Dimmwert EF 27
0​
560​
IDE05145-ENG116417-Light configuration-Dimmwert EF 28
0​
560​
IDE05145-ENG116436-Light configuration-Dimmwert EF 29
0​
560​
IDE05145-ENG115942-Light configuration-Dimmwert EF 3
0​
560​
IDE05145-ENG116455-Light configuration-Dimmwert EF 30
100​
560​
IDE05145-ENG116474-Light configuration-Dimmwert EF 31
0​
560​
IDE05145-ENG116493-Light configuration-Dimmwert EF 32
0​
560​
IDE05145-ENG116512-Light configuration-Dimmwert EF 33
0​
560​
IDE05145-ENG116531-Light configuration-Dimmwert EF 34
0​
560​
IDE05145-ENG115961-Light configuration-Dimmwert EF 4
31​
560​
IDE05145-ENG115980-Light configuration-Dimmwert EF 5
31​
560​
IDE05145-ENG115999-Light configuration-Dimmwert EF 6
0​
560​
IDE05145-ENG116018-Light configuration-Dimmwert EF 7
0​
560​
IDE05145-ENG116037-Light configuration-Dimmwert EF 8
0​
560​
IDE05145-ENG116056-Light configuration-Dimmwert EF 9
0​
560​
IDE05145-ENG115890-Light configuration-Dimmwert GH 0
0​
560​
IDE05145-ENG115908-Light configuration-Dimmwert GH 1
0​
560​
IDE05145-ENG116079-Light configuration-Dimmwert GH 10
0​
560​
IDE05145-ENG116098-Light configuration-Dimmwert GH 11
0​
560​
IDE05145-ENG116117-Light configuration-Dimmwert GH 12
0​
560​
IDE05145-ENG116136-Light configuration-Dimmwert GH 13
0​
560​
IDE05145-ENG116155-Light configuration-Dimmwert GH 14
0​
560​
IDE05145-ENG116174-Light configuration-Dimmwert GH 15
0​
560​
IDE05145-ENG116193-Light configuration-Dimmwert GH 16
0​
560​
IDE05145-ENG116212-Light configuration-Dimmwert GH 17
0​
560​
IDE05145-ENG116231-Light configuration-Dimmwert GH 18
0​
560​
IDE05145-ENG116250-Light configuration-Dimmwert GH 19
0​
560​
IDE05145-ENG115927-Light configuration-Dimmwert GH 2
25​
560​
IDE05145-ENG116269-Light configuration-Dimmwert GH 20
0​
560​
IDE05145-ENG116288-Light configuration-Dimmwert GH 21
0​
560​
IDE05145-ENG116307-Light configuration-Dimmwert GH 22
0​
560​
IDE05145-ENG116326-Light configuration-Dimmwert GH 23
0​
560​
IDE05145-ENG116345-Light configuration-Dimmwert GH 24
0​
560​
IDE05145-ENG116364-Light configuration-Dimmwert GH 25
0​
560​
IDE05145-ENG116383-Light configuration-Dimmwert GH 26
0​
560​
IDE05145-ENG116402-Light configuration-Dimmwert GH 27
0​
560​
IDE05145-ENG116421-Light configuration-Dimmwert GH 28
0​
560​
IDE05145-ENG116440-Light configuration-Dimmwert GH 29
0​
560​
IDE05145-ENG115946-Light configuration-Dimmwert GH 3
25​
560​
IDE05145-ENG116459-Light configuration-Dimmwert GH 30
100​
560​
IDE05145-ENG116478-Light configuration-Dimmwert GH 31
0​
560​
IDE05145-ENG116497-Light configuration-Dimmwert GH 32
0​
560​
IDE05145-ENG116516-Light configuration-Dimmwert GH 33
0​
560​
IDE05145-ENG116535-Light configuration-Dimmwert GH 34
0​
560​
IDE05145-ENG115965-Light configuration-Dimmwert GH 4
0​
560​
IDE05145-ENG115984-Light configuration-Dimmwert GH 5
0​
560​
IDE05145-ENG116003-Light configuration-Dimmwert GH 6
0​
560​
IDE05145-ENG116022-Light configuration-Dimmwert GH 7
0​
560​
IDE05145-ENG116041-Light configuration-Dimmwert GH 8
0​
560​
IDE05145-ENG116060-Light configuration-Dimmwert GH 9
0​
560​
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0
14​
560​
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1
15​
560​
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10
0​
560​
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11
0​
560​
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12
22​
560​
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13
23​
560​
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14
0​
560​
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15
0​
560​
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16
0​
560​
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17
0​
560​
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18
0​
560​
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19
0​
560​
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2
45​
560​
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 203D
560​
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 213E
560​
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 222C
560​
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23
29​
560​
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 242A
560​
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25
30​
560​
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26
0​
560​
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27
47​
560​
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28
31​
560​
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29
32​
560​
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3
46​
560​
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30
2​
560​
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31
0​
560​
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32
0​
560​
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33
0​
560​
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34
0​
560​
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4
43​
560​
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5
44​
560​
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 61A
560​
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 71B
560​
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 81C
560​
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 91D
560​
IDE05145-ENG115873-Light configuration-Lasttyp 012 - Blinkleuchten
560​
IDE05145-ENG115892-Light configuration-Lasttyp 112 - Blinkleuchten
560​
IDE05145-ENG116062-Light configuration-Lasttyp 10not active
560​
IDE05145-ENG116081-Light configuration-Lasttyp 11not active
560​
IDE05145-ENG116100-Light configuration-Lasttyp 1210 - allgemeine Scheinwerfer
560​
IDE05145-ENG116119-Light configuration-Lasttyp 1310 - allgemeine Scheinwerfer
560​
IDE05145-ENG116138-Light configuration-Lasttyp 14not active
560​
IDE05145-ENG116157-Light configuration-Lasttyp 15not active
560​
IDE05145-ENG116176-Light configuration-Lasttyp 16not active
560​
IDE05145-ENG116195-Light configuration-Lasttyp 17not active
560​
IDE05145-ENG116214-Light configuration-Lasttyp 18not active
560​
IDE05145-ENG116233-Light configuration-Lasttyp 19not active
560​
IDE05145-ENG115910-Light configuration-Lasttyp 28 - allgemeine Glühlampe 12W
560​
IDE05145-ENG116252-Light configuration-Lasttyp 2014 - kombinierte Blink- Bremsleuchten
560​
IDE05145-ENG116271-Light configuration-Lasttyp 2114 - kombinierte Blink- Bremsleuchten
560​
IDE05145-ENG116290-Light configuration-Lasttyp 2242 - LED dritte Bremsleuchte
560​
IDE05145-ENG116309-Light configuration-Lasttyp 239 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG116328-Light configuration-Lasttyp 249 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG116347-Light configuration-Lasttyp 2518 - 2* 5W
560​
IDE05145-ENG116366-Light configuration-Lasttyp 26not active
560​
IDE05145-ENG116385-Light configuration-Lasttyp 2736 - LED Kleinleistung
560​
IDE05145-ENG116404-Light configuration-Lasttyp 289 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG116423-Light configuration-Lasttyp 299 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG115929-Light configuration-Lasttyp 38 - allgemeine Glühlampe 12W
560​
IDE05145-ENG116442-Light configuration-Lasttyp 3036 - LED Kleinleistung
560​
IDE05145-ENG116461-Light configuration-Lasttyp 31not active
560​
IDE05145-ENG116480-Light configuration-Lasttyp 32not active
560​
IDE05145-ENG116499-Light configuration-Lasttyp 33not active
560​
IDE05145-ENG116518-Light configuration-Lasttyp 34not active
560​
IDE05145-ENG115948-Light configuration-Lasttyp 49 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG115967-Light configuration-Lasttyp 59 - allgemeine Glühlampe 27W: auch H15
560​
IDE05145-ENG115986-Light configuration-Lasttyp 611 - Abblendlicht
560​
IDE05145-ENG116005-Light configuration-Lasttyp 711 - Abblendlicht
560​
IDE05145-ENG116024-Light configuration-Lasttyp 810 - allgemeine Scheinwerfer
560​
IDE05145-ENG116043-Light configuration-Lasttyp 910 - allgemeine Scheinwerfer
560​
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0Always
560​
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1Always
560​
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10Always
560​
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11Always
560​
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12Always
560​
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13Always
560​
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14Always
560​
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15Always
560​
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16Always
560​
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17Always
560​
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18Always
560​
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19Always
560​
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2Always
560​
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20Always
560​
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21Always
560​
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22Always
560​
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23Always
560​
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24Always
560​
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25Always
560​
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26Always
560​
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27Always
560​
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28Always
560​
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29Always
560​
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3Always
560​
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30Always
560​
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31Always
560​
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32Always
560​
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33Always
560​
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34Always
560​
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4Always
560​
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5Always
560​
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6Always
560​
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7Always
560​
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8Always
560​
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9Always
560​
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17
0​
560​
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13
0​
560​
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0
2​
560​
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1
4​
560​
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10
0​
560​
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11
0​
560​
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12
18​
560​
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13
18​
560​
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14
0​
560​
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15
0​
560​
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16
0​
560​
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17
0​
560​
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18
0​
560​
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19
0​
560​
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2
8​
560​
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20
24​
560​
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21
24​
560​
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22
24​
560​
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23
8​
560​
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24
8​
560​
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25
8​
560​
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26
0​
560​
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27
26​
560​
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28
25​
560​
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29
25​
560​
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3
8​
560​
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30
43​
560​
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31
0​
560​
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32
0​
560​
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33
0​
560​
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34
0​
560​
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4
20​
560​
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5
20​
560​
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6
11​
560​
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7
12​
560​
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8
13​
560​
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9
14​
560​
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0
0​
560​
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1
0​
560​
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10
0​
560​
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11
0​
560​
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12
22​
560​
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13
23​
560​
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14
0​
560​
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15
0​
560​
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16
0​
560​
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18
0​
560​
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19
0​
560​
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2
0​
560​
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20
2​
560​
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21
4​
560​
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22
0​
560​
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23
0​
560​
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24
0​
560​
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25
0​
560​
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26
0​
560​
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27
0​
560​
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28
0​
560​
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29
0​
560​
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3
0​
560​
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30
43​
560​
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31
0​
560​
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32
0​
560​
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33
0​
560​
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34
0​
560​
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4
0​
560​
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5
0​
560​
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6
0​
560​
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7
0​
560​
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8
15​
560​
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9
15​
560​
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0
0​
560​
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1
0​
560​
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10
0​
560​
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11
0​
560​
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12
20​
560​
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14
0​
560​
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15
0​
560​
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16
0​
560​
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17
0​
560​
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18
0​
560​
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19
0​
560​
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2
0​
560​
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20
3​
560​
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21
5​
560​
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22
0​
560​
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23
0​
560​
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24
0​
560​
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25
0​
560​
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26
0​
560​
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27
0​
560​
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28
0​
560​
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29
0​
560​
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3
0​
560​
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30
30​
560​
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31
0​
560​
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32
0​
560​
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33
0​
560​
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34
0​
560​
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4
0​
560​
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5
0​
560​
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6
0​
560​
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7
0​
560​
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8
0​
560​
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9
0​
560​
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0
0​
560​
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1
0​
560​
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10
0​
560​
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11
0​
560​
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12
0​
560​
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13
0​
560​
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14
0​
560​
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15
0​
560​
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16
0​
560​
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17
0​
560​
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18
0​
560​
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19
0​
560​
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2
0​
560​
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20
0​
560​
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21
0​
560​
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22
0​
560​
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23
0​
560​
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24
0​
560​
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25
0​
560​
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26
0​
560​
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27
0​
560​
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28
0​
560​
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29
0​
560​
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3
0​
560​
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30
0​
560​
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31
0​
560​
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32
0​
560​
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33
0​
560​
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34
0​
560​
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4
0​
560​
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5
0​
560​
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6
0​
560​
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7
0​
560​
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8
0​
560​
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9
0​
560​
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0
0​
560​
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1
0​
560​
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10
0​
560​
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11
0​
560​
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12
13​
560​
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13
14​
560​
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14
0​
560​
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15
0​
560​
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16
0​
560​
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17
0​
560​
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18
0​
560​
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19
0​
560​
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2
0​
560​
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20
8​
560​
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21
8​
560​
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22
0​
560​
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23
0​
560​
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24
0​
560​
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25
0​
560​
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26
0​
560​
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27
0​
560​
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28
0​
560​
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29
0​
560​
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3
0​
560​
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30
0​
560​
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31
0​
560​
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32
0​
560​
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33
0​
560​
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34
0​
560​
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4
8​
560​
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5
8​
560​
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6
0​
560​
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7
0​
560​
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8
0​
560​
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9
0​
560​
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0
0​
560​
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1
0​
560​
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10
0​
560​
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11
0​
560​
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12
15​
560​
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13
15​
560​
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14
0​
560​
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15
0​
560​
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16
0​
560​
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17
0​
560​
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18
0​
560​
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19
0​
560​
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2
0​
560​
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20
0​
560​
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21
0​
560​
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22
0​
560​
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23
0​
560​
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24
0​
560​
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25
0​
560​
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26
0​
560​
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27
0​
560​
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28
0​
560​
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29
0​
560​
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30
0​
560​
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31
0​
560​
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32
0​
560​
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33
0​
560​
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34
0​
560​
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4
0​
560​
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6
0​
560​
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7
0​
560​
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8
0​
560​
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9
0​
560​
IDE05145-ENG115941-Light configuration-Lichtfunktion F3
0​
560​
IDE05145-ENG115979-Light configuration-Lichtfunktion F5
0​
560​
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0
0​
560​
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1
0​
560​
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10
0​
560​
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11
0​
560​
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12
0​
560​
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13
0​
560​
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14
0​
560​
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15
0​
560​
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16
0​
560​
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17
0​
560​
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18
0​
560​
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19
0​
560​
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2
6​
560​
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20
0​
560​
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21
0​
560​
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22
0​
560​
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23
0​
560​
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24
0​
560​
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25
0​
560​
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26
0​
560​
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27
0​
560​
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28
0​
560​
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29
0​
560​
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3
7​
560​
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30
0​
560​
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31
0​
560​
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32
0​
560​
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33
0​
560​
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34
0​
560​
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4
0​
560​
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5
0​
560​
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6
0​
560​
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7
0​
560​
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8
0​
560​
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9
0​
560​
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0
0​
560​
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1
0​
560​
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10
0​
560​
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11
0​
560​
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12
0​
560​
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13
0​
560​
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14
0​
560​
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15
0​
560​
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16
0​
560​
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17
0​
560​
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18
0​
560​
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19
0​
560​
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2
0​
560​
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20
0​
560​
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21
0​
560​
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22
0​
560​
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23
0​
560​
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24
0​
560​
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25
0​
560​
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26
0​
560​
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27
0​
560​
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28
0​
560​
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29
0​
560​
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3
0​
560​
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30
0​
560​
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31
0​
560​
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32
0​
560​
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33
0​
560​
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34
0​
560​
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4
0​
560​
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5
0​
560​
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6
0​
560​
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7
0​
560​
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8
0​
560​
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9
0​
560​
IDE05145-ENG154438-Light configuration-Reserved 0
0​
560​
IDE05145-ENG99841-Light configuration-Reserved 1
0​
560​
IDE05145-ENG154357-Light configuration-Reserved 10
0​
560​
IDE05145-ENG154352-Light configuration-Reserved 11
0​
560​
IDE05145-ENG154182-Light configuration-Reserved 12
0​
560​
IDE05145-ENG154265-Light configuration-Reserved 13
0​
560​
IDE05145-ENG154334-Light configuration-Reserved 14
0​
560​
IDE05145-ENG154340-Light configuration-Reserved 15
0​
560​
IDE05145-ENG154204-Light configuration-Reserved 16
0​
560​
IDE05145-ENG154344-Light configuration-Reserved 17
0​
560​
IDE05145-ENG154195-Light configuration-Reserved 18
0​
560​
IDE05145-ENG154190-Light configuration-Reserved 19
0​
560​
IDE05145-ENG99862-Light configuration-Reserved 2
0​
560​
IDE05145-ENG154300-Light configuration-Reserved 20
0​
560​
IDE05145-ENG154439-Light configuration-Reserved 21
0​
560​
IDE05145-ENG154440-Light configuration-Reserved 22
0​
560​
IDE05145-ENG154441-Light configuration-Reserved 23
0​
560​
IDE05145-ENG154442-Light configuration-Reserved 24
0​
560​
IDE05145-ENG154443-Light configuration-Reserved 25
0​
560​
IDE05145-ENG154444-Light configuration-Reserved 26
0​
560​
IDE05145-ENG154445-Light configuration-Reserved 27
0​
560​
IDE05145-ENG154446-Light configuration-Reserved 28
0​
560​
IDE05145-ENG154447-Light configuration-Reserved 29
0​
560​
IDE05145-ENG101107-Light configuration-Reserved 3
0​
560​
IDE05145-ENG154448-Light configuration-Reserved 30
0​
560​
IDE05145-ENG154449-Light configuration-Reserved 31
0​
560​
IDE05145-ENG154450-Light configuration-Reserved 32
0​
560​
IDE05145-ENG154451-Light configuration-Reserved 33
0​
560​
IDE05145-ENG154452-Light configuration-Reserved 34
0​
560​
IDE05145-ENG154267-Light configuration-Reserved 4
0​
560​
IDE05145-ENG154291-Light configuration-Reserved 5
0​
560​
IDE05145-ENG154239-Light configuration-Reserved 6
0​
560​
IDE05145-ENG154308-Light configuration-Reserved 7
0​
560​
IDE05145-ENG154184-Light configuration-Reserved 8
0​
560​
IDE05145-ENG154255-Light configuration-Reserved 9
0​
560​
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss1 s
24​
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss0.00 °C
24​
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle22.50 °C
24​
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle21.50 °C
24​
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle22.50 °C
24​
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle21.50 °C
24​
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle36.00 °C
24​
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle35.00 °C
24​
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle36.00 °C
24​
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle35.00 °C
24​
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle53.50 °C
24​
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle52.50 °C
24​
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle53.50 °C
24​
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle52.50 °C
24​
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschaltenactive
8​
IDE06096-ENG116597-Interior lights-KL30G ohne PWMnot active
8​
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampenot active
8​
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschaltennot active
8​
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtungactive
8​
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert
100%​
8​
IDE06425-Dynamometer mode: functionalnot active
1​
IDE06507-MAS13125-Button in center console-Function of button 1Start-stop
8​
IDE06507-MAS13129-Button in center console-Function of button 2Luggage hold closure
8​
IDE06507-MAS13132-Button in center console-Function of button 3Driving program
8​
IDE06507-MAS13135-Button in center console-Function of button 4Steering wheel heating
8​
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei TagDaytime running lamps
4​
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlichtnot active
4​
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlichtactive
4​
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglichactive
4​
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschaltenactive
4​
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTOactive
4​
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlichtnot active
4​
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchtenot active
4​
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolgeactive
4​
IDE07356-Position during interval mode31.49 °
2​
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufsabschalten nach der Nachlaufzeit
12​
IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzungbegrenzen auf Mindestverfügbarkeit
12​
IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzungbegrenzen auf Mindestverfügbarkeit
12​
IDE07470-ENG133382-After-run for park light-Faktor fuer VerfügbarkeitstimerFaktor fuer x5 Minuten
12​
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit30 min
12​
IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit6 s
12​
IDE08542-IDE02021-Access control 2-Comfort closingactive
8​
IDE08542-IDE02022-Access control 2-Comfort openingnot active
8​
IDE08542-ENG128459-Access control 2-easycloselight_aktivnot active
8​
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnenactive
8​
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessennot active
8​
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit600 s
8​
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 ausactive
8​
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechenactive
8​
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnennot active
8​
IDE08542-ENG116651-Access control 2-Funk Komfort schliessennot active
8​
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappenactive
8​
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modusby look command via remote control key
8​
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnennot active
8​
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessenactive
8​
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzungnot active
8​
IDE08542-ENG115670-Access control 2-Komfortbedienung globalactive
8​
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuernot active
8​
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappenactive
8​
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbaradjustable
8​
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessennot active
8​
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkungnot active
8​
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellungnot active
8​
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklaufnot active
8​
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegelactive
8​
IDE08542-ENG125656-Access control 2-Regenschliessen_artonce
8​
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_ausnot active
8​
IDE08542-ENG125657-Access control 2-Remote_Unlock_LockVia ZV-Absicherung Light
8​
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnennot active
8​
IDE08542-ENG116646-Access control 2-SAD Komfort schliessennot active
8​
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessennot active
8​
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnentilting
8​
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnennot active
8​
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessennot active
8​
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappungactive
8​
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrtnot active
8​
IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelungnot active
8​
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchronnot active
8​
IDE08542-ENG115869-Access control 2-Virtuelles_Pedalnot active
8​
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbarnot active
8​
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung0 ms
8​
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regenactive
8​
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfachnot active
8​
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfigkein_Hinweis
8​
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Resetnot active
8​
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert0 ms
8​
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeitnormal
8​
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabenot active
8​
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistentnot installed
8​
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellungpresent
8​
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBAnot active
8​
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchtenot active
8​
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgebenactive
2​
IDE08787-ENG101416-Auxiliary functions-Reserved_1not active
2​
IDE08787-ENG99458-Auxiliary functions-Reserved_2not active
2​
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15active
2​
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahrennot active
2​
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FTnot active
2​
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinkennot active
4​
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashingnot active
4​
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinkennot active
4​
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittungnot active
4​
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinkennot active
4​
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinkennot active
4​
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2not active
4​
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashingnot active
4​
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_linksnot active
4​
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechtsnot active
4​
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinkennot active
4​
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashingnot active
4​
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinkennot active
4​
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinkennot active
4​
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUSnot active
4​
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EINnot active
4​
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_aufnot active
4​
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zunot active
4​
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit0.10 s
20​
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1
2​
20​
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2
3​
20​
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3
1​
20​
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1
225​
20​
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2
225​
20​
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3
225​
20​
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbignot active
20​
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbignot active
20​
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach
80%​
20​
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe
2​
20​
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole
80%​
20​
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnenactive
20​
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnenactive
20​
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnenactive
20​
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnennot active
20​
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1
225​
20​
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2
225​
20​
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3
225​
20​
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnenactive
20​
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnenactive
20​
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnenactive
20​
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnennot active
20​
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbigactive
20​
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbignot active
20​
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbignot active
20​
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivierennot active
20​
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbignot active
20​
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1
100​
20​
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2
225​
20​
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3
225​
20​
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbigactive
20​
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechselnot active
20​
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMInot active
2​
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafelinstalled
2​
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafelnot installed
2​
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprechernot installed
2​
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonenactive
2​
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem ausactive
2​
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtunginstalled
2​
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtungnot installed
2​
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofilnot installed
2​
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMIinstalled
2​
IDE09732-ENG114629-Interior light: light configuration-Footwell lightinginstalled
2​
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMInot active
2​
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbarnot active
2​
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtunginstalled
2​
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtungnot installed
2​
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne
30%​
12​
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz
25%​
12​
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne
30%​
12​
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz
25%​
12​
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne
58%​
12​
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz
53%​
12​
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne
58%​
12​
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz
53%​
12​
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne
85%​
12​
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz
80%​
12​
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne
85%​
12​
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz
80%​
12​
IDE10298-Alternating park position 17.49 °
2​
IDE10299-Alternating park position 229.49 °
2​
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit
64​
256​
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach
64​
256​
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum
14​
256​
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel
64​
256​
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher
64​
256​
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko
64​
256​
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd
64​
256​
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer
0​
256​
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMIFF
256​
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2FF
256​
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3E1
256​
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4E1
256​
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI
0​
256​
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2
0​
256​
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3
0​
256​
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4
0​
256​
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab
1​
256​
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf
1​
256​
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI
0​
256​
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay
0​
256​
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum
0%​
256​
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum
0%​
256​
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum
0%​
256​
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum
70%​
256​
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit
100%​
256​
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach
100%​
256​
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum
0%​
256​
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht
100%​
256​
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel
100%​
256​
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher
100%​
256​
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko
100%​
256​
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd
100%​
256​
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren
0%​
256​
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit
100%​
256​
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach
100%​
256​
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum
0%​
256​
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht
100%​
256​
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel
100%​
256​
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher
100%​
256​
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko
100%​
256​
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd
100%​
256​
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren
0%​
256​
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum
0%​
256​
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel
100%​
256​
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren
0%​
256​
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach
100%​
256​
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum
0%​
256​
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko
100%​
256​
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd
100%​
256​
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit
126%​
256​
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach
126%​
256​
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum
0%​
256​
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht
0%​
256​
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel
126%​
256​
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher
126%​
256​
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko
126%​
256​
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd
126%​
256​
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum
127%​
256​
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum
126%​
256​
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit
100%​
256​
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach
100%​
256​
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum
100%​
256​
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht
100%​
256​
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel
100%​
256​
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher
100%​
256​
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko
100%​
256​
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd
100%​
256​
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren
0%​
256​
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum
0%​
256​
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach
100%​
256​
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum
0%​
256​
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko
100%​
256​
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd
100%​
256​
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum
0%​
256​
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel
100%​
256​
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren
0%​
256​
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte0 ms
256​
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit0 s
256​
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach0 s
256​
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum0 s
256​
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht0 s
256​
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko0 s
256​
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren0 s
256​
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit0 s
256​
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach0 s
256​
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum0 s
256​
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht0 s
256​
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko0 s
256​
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren0 s
256​
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit0 s
256​
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach0 s
256​
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum0 s
256​
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht0 s
256​
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko0 s
256​
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren0 s
256​
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit0 s
256​
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach0 s
256​
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum0 s
256​
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht0 s
256​
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko0 s
256​
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren0 s
256​
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit0 s
256​
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach0 s
256​
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum0 s
256​
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht0 s
256​
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko0 s
256​
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren0 s
256​
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit0 s
256​
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach0 s
256​
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum0 s
256​
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht0 s
256​
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko0 s
256​
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren0 s
256​
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit0 s
256​
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach0 s
256​
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum0 s
256​
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht0 s
256​
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko0 s
256​
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren0 s
256​
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen
0​
256​
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10E1
30​
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4E1
30​
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5E1
30​
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6E1
30​
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7E1
30​
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8E1
30​
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9E1
30​
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10E1
30​
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4E1
30​
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5E1
30​
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6E1
30​
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7E1
30​
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8E1
30​
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9E1
30​
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10E1
30​
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4E1
30​
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5E1
30​
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6E1
30​
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7E1
30​
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8E1
30​
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9E1
30​
MAS01490-ENG116830-Energy management-Energy_Management_AdaptationEnergy management active
1​
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagementnot active
1​
MAS05055-lower turn position31.49 °
2​
MAS05056-upper turn position170.49 °
2​
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeckactive
8​
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetriebnot active
8​
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SGnot active
8​
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck globalactive
8​
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnenactive
8​
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließenactive
8​
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessennot active
8​
MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s10 s
8​
MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s30.000 ms
8​
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedachnot active
8​
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienungactive
8​
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessyactive
8​
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinderactive
8​
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienungactive
8​
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessyactive
8​
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinderactive
8​
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Einnot active
8​
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze60 lx
24​
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze110 lx
24​
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle1000 lx
24​
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO30 lx
24​
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten60 lx
24​
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten110 lx
24​
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red
80​
24​
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell100 lx
24​
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung4500 mV
24​
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke300 lx
24​
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung2000 mV
24​
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke0 lx
24​
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung
2​
24​
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1
1​
30​
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10
1​
30​
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11
1​
30​
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12
1​
30​
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13
1​
30​
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14
1​
30​
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15
1​
30​
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2
1​
30​
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3
1​
30​
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4
1​
30​
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5
1​
30​
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6
1​
30​
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7
1​
30​
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8
1​
30​
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9
1​
30​
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1door
30​
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10door
30​
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11door
30​
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12door
30​
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13door
30​
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14door
30​
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15door
30​
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2door
30​
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3door
30​
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4door
30​
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5door
30​
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6door
30​
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7door
30​
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8door
30​
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9door
30​
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1not installed
30​
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10not installed
30​
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11not installed
30​
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12not installed
30​
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13not installed
30​
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14not installed
30​
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15not installed
30​
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2not installed
30​
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3not installed
30​
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4not installed
30​
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5not installed
30​
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6not installed
30​
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7not installed
30​
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8not installed
30​
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9not installed
30​
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12
0​
60​
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1
0​
60​
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10
0​
60​
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11
0​
60​
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13
0​
60​
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14
0​
60​
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15
0​
60​
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16
0​
60​
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17
0​
60​
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18
0​
60​
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19
0​
60​
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2
0​
60​
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20
0​
60​
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3
0​
60​
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4
0​
60​
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5
0​
60​
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6
0​
60​
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7
0​
60​
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8
0​
60​
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9
0​
60​
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1
0​
60​
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10
0​
60​
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11
0​
60​
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12
0​
60​
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13
0​
60​
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14
0​
60​
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15
0​
60​
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16
0​
60​
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17
0​
60​
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18
0​
60​
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19
0​
60​
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2
0​
60​
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20
0​
60​
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3
0​
60​
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4
0​
60​
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5
0​
60​
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6
0​
60​
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7
0​
60​
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9
0​
60​
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8
0​
60​
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1not installed
60​
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10not installed
60​
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11not installed
60​
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12not installed
60​
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13not installed
60​
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14not installed
60​
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15not installed
60​
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16not installed
60​
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17not installed
60​
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18not installed
60​
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19not installed
60​
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2not installed
60​
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20not installed
60​
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3not installed
60​
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4not installed
60​
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5not installed
60​
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6not installed
60​
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7not installed
60​
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9not installed
60​
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8not installed
60​
ENG126647-ENG98399-debug_light_function-Activation
0​
11​
ENG126647-ENG101417-debug_light_function-Adresse
0​
11​
ENG126647-ENG126820-debug_light_function-Bitmask
0​
11​
ENG126647-ENG126821-debug_light_function-Divisor
0​
11​
ENG126647-ENG98827-debug_light_function-Offset
0​
11​
ENG126647-ENG126822-debug_light_function-Polaritaet
0​
11​
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe
0​
11​
ENG99457-ENG117394-Head area heater-blower_speed
1​
2​
ENG99457-ENG98971-Head area heater-Temperature
-2​
2​
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x00 ms
22​
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1200 ms
22​
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x102000 ms
22​
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2400 ms
22​
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3600 ms
22​
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4800 ms
22​
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X51000 ms
22​
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X61200 ms
22​
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x71400 ms
22​
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x81600 ms
22​
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x91800 ms
22​
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0
100.00%​
22​
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1
72.00%​
22​
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10
0.00%​
22​
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2
48.00%​
22​
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3
33.00%​
22​
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4
18.00%​
22​
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5
12.00%​
22​
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6
8.00%​
22​
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7
6.00%​
22​
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8
4.00%​
22​
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9
2.00%​
22​
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0
0​
22​
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1
50​
22​
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10
0​
22​
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2
100​
22​
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3
200​
22​
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4
253​
22​
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5
0​
22​
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6
0​
22​
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7
0​
22​
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8
0​
22​
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9
0​
22​
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y00 lx
22​
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y150 lx
22​
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y100 lx
22​
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2100 lx
22​
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3
200​
22​
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4
500​
22​
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5
0​
22​
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y60 lx
22​
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y70 lx
22​
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y80 lx
22​
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y90 lx
22​
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x00 ms
22​
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1200 ms
22​
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x102000 ms
22​
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2400 ms
22​
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3600 ms
22​
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4800 ms
22​
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X51000 ms
22​
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X61200 ms
22​
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x71400 ms
22​
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x81600 ms
22​
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x91800 ms
22​
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0
0.00%​
22​
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1
1.00%​
22​
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10
100.00%​
22​
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2
3.00%​
22​
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3
5.00%​
22​
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4
11.00%​
22​
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5
22.00%​
22​
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6
40.00%​
22​
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7
80.00%​
22​
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8
95.00%​
22​
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9
100.00%​
22​
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0
0.00%​
12​
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1
6.00%​
12​
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2
16.00%​
12​
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3
30.00%​
12​
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4
60.00%​
12​
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5
100.00%​
12​
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0
10​
12​
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1
10​
12​
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2
100​
12​
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3
150​
12​
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4
220​
12​
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5
253​
12​
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x00 lx
10​
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X18 lx
10​
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2200 lx
10​
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3300 lx
10​
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4500 lx
10​
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0
16​
10​
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1
16​
10​
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2
100​
10​
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3
100​
10​
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4
100​
10​
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x00 lx
10​
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X18 lx
10​
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2220 lx
10​
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3300 lx
10​
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4500 lx
10​
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0
6​
10​
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1
6​
10​
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2
100​
10​
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3
100​
10​
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4
100​
10​
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0
0​
12​
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1
10​
12​
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2
50​
12​
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3
100​
12​
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4
220​
12​
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5
253​
12​
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0
2.00%​
12​
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1
2.00%​
12​
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2
6.00%​
12​
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3
10.00%​
12​
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4
80.00%​
12​
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5
100.00%​
12​
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x00 lx
8​
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X18 lx
8​
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X250 lx
8​
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3500 lx
8​
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0
100​
8​
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1
100​
8​
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2
100​
8​
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3
100​
8​
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x00 lx
8​
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X18 lx
8​
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X250 lx
8​
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3500 lx
8​
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0
6​
8​
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1
6​
8​
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2
100​
8​
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3
100​
8​
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0
0.00%​
6​
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1
50.00%​
6​
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2
100.00%​
6​
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0
0.00%​
6​
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1
50.00%​
6​
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2
100.00%​
6​
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x00 lx
8​
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X18 lx
8​
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X250 lx
8​
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3500 lx
8​
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0
100​
8​
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1
100​
8​
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2
100​
8​
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3
100​
8​
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x00 lx
8​
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X18 lx
8​
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X250 lx
8​
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3500 lx
8​
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0
6​
8​
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1
6​
8​
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2
100​
8​
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3
100​
8​
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0
0.00%​
6​
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1
50.00%​
6​
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2
100.00%​
6​
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0
0.00%​
6​
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1
50.00%​
6​
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2
100.00%​
6​
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x00 ms
10​
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1100 ms
10​
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2160 ms
10​
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3200 ms
10​
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4260 ms
10​
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0
1.00%​
10​
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1
5​
10​
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2
15​
10​
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3
10​
10​
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4
100​
10​
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0maximize
16​
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0maximize
16​
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0maximize
16​
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0
100​
16​
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0
0​
16​
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0
0​
16​
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0
0​
16​
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0
14​
16​
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0
34​
16​
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 012 - Blinkleuchten
16​
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0Always
16​
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0Blinken links Hellphase
16​
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0not active
16​
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0not active
16​
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0not active
16​
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0not active
16​
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0not active
16​
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0not active
16​
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0not active
16​
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10maximize
16​
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10maximize
16​
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10maximize
16​
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10
0​
16​
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10
0​
16​
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10
0​
16​
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10
0​
16​
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10
0​
16​
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10
0​
16​
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10not active
16​
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10Always
16​
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10not active
16​
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10not active
16​
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10not active
16​
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10not active
16​
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10not active
16​
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10not active
16​
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10not active
16​
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10not active
16​
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11maximize
16​
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11maximize
16​
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11maximize
16​
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11
0​
16​
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11
0​
16​
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11
0​
16​
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11
0​
16​
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11
0​
16​
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11
0​
16​
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11not active
16​
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11Always
16​
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11not active
16​
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11not active
16​
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11not active
16​
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11not active
16​
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11not active
16​
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11not active
16​
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11not active
16​
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11not active
16​
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12maximize
16​
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12maximize
16​
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12maximize
16​
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12
100​
16​
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12
0​
16​
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12
100​
16​
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12
0​
16​
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12
22​
16​
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12
38​
16​
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 1210 - allgemeine Scheinwerfer
16​
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12Always
16​
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12Nebellicht links
16​
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12Abbiegelicht links
16​
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12Daytime running lamps
16​
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12not active
16​
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12Left high beam
16​
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12Lichthupe generell
16​
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12not active
16​
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12not active
16​
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13maximize
16​
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13maximize
16​
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13maximize
16​
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13
100​
16​
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13
0​
16​
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13
100​
16​
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13
0​
16​
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13
23​
16​
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13
42​
16​
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 1310 - allgemeine Scheinwerfer
16​
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13Always
16​
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13Nebellicht links
16​
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13Abbiegelicht rechts
16​
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13not active
16​
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13not active
16​
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13Right high beam
16​
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13Lichthupe generell
16​
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13not active
16​
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13not active
16​
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15maximize
16​
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15maximize
16​
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15maximize
16​
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15
0​
16​
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15
0​
16​
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15
0​
16​
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15
0​
16​
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15
0​
16​
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15
0​
16​
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15not active
16​
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15Always
16​
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15not active
16​
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15not active
16​
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15not active
16​
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15not active
16​
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15not active
16​
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15not active
16​
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15not active
16​
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15not active
16​
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16maximize
16​
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16maximize
16​
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16maximize
16​
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
0​
16​
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16
0​
16​
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16
0​
16​
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16
0​
16​
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16
0​
16​
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16
0​
16​
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16not active
16​
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16Always
16​
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16not active
16​
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16not active
16​
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16not active
16​
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16not active
16​
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16not active
16​
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16not active
16​
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16not active
16​
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16not active
16​
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17maximize
16​
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17maximize
16​
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17maximize
16​
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17
0​
16​
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17
0​
16​
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17
0​
16​
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17
0​
16​
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17
0​
16​
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17
0​
16​
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17not active
16​
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17Always
16​
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17not active
16​
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17not active
16​
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17not active
16​
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17not active
16​
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17not active
16​
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17not active
16​
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17not active
16​
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17not active
16​
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18maximize
16​
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18maximize
16​
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18maximize
16​
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18
0​
16​
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18
0​
16​
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18
0​
16​
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18
0​
16​
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18
0​
16​
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18
0​
16​
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18not active
16​
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18Always
16​
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18not active
16​
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18not active
16​
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18not active
16​
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18not active
16​
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18not active
16​
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18not active
16​
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18not active
16​
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18not active
16​
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19maximize
16​
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19maximize
16​
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19maximize
16​
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19
0​
16​
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19
0​
16​
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19
0​
16​
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19
0​
16​
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19
0​
16​
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19
0​
16​
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19not active
16​
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19Always
16​
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19not active
16​
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19not active
16​
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19not active
16​
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19not active
16​
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19not active
16​
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19not active
16​
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19not active
16​
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19not active
16​
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1maximize
16​
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1maximize
16​
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1maximize
16​
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1
100​
16​
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1
0​
16​
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1
0​
16​
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1
0​
16​
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1
15​
16​
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 13E
16​
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 112 - Blinkleuchten
16​
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1Always
16​
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1Blinken rechts Hellphase
16​
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1not active
16​
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1not active
16​
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1not active
16​
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1not active
16​
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1not active
16​
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1not active
16​
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1not active
16​
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20minimize
16​
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20maximize
16​
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20maximize
16​
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20
100​
16​
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20
0​
16​
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20
28​
16​
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20
0​
16​
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 203D
16​
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20
13​
16​
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 2014 - kombinierte Blink- Bremsleuchten
16​
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20Always
16​
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20Brake lamp
16​
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20Blinken links Hellphase
16​
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20Blinken links Dunkelphase
16​
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20not active
16​
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20not active
16​
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20not active
16​
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20not active
16​
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21minimize
16​
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21maximize
16​
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21maximize
16​
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21
100​
16​
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21
0​
16​
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21
28​
16​
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21
0​
16​
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 213E
16​
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21
23​
16​
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 2114 - kombinierte Blink- Bremsleuchten
16​
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21Always
16​
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21Brake lamp
16​
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21Blinken rechts Hellphase
16​
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21Blinken rechts Dunkelphase
16​
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21not active
16​
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21not active
16​
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21not active
16​
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21not active
16​
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22maximize
16​
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22maximize
16​
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22maximize
16​
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22
100​
16​
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22
0​
16​
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22
0​
16​
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22
0​
16​
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 222C
16​
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22
29​
16​
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 2242 - LED dritte Bremsleuchte
16​
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22Always
16​
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22Brake lamp
16​
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22not active
16​
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22not active
16​
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22not active
16​
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22not active
16​
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22not active
16​
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22not active
16​
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22not active
16​
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23maximize
16​
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23maximize
16​
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23maximize
16​
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23
28​
16​
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23
0​
16​
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23
0​
16​
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23
0​
16​
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23
29​
16​
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 230A
16​
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 239 - allgemeine Glühlampe 27W: auch H15
16​
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23Always
16​
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23not active
16​
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23not active
16​
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23not active
16​
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23not active
16​
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23not active
16​
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23not active
16​
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23not active
16​
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24maximize
16​
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24maximize
16​
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24maximize
16​
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24
28​
16​
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24
0​
16​
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24
0​
16​
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24
0​
16​
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 242A
16​
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 241A
16​
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 249 - allgemeine Glühlampe 27W: auch H15
16​
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24Always
16​
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24not active
16​
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24not active
16​
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24not active
16​
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24not active
16​
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24not active
16​
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24not active
16​
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24not active
16​
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25maximize
16​
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25maximize
16​
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25maximize
16​
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25
100​
16​
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25
0​
16​
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25
0​
16​
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25
0​
16​
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25
30​
16​
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25
28​
16​
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 2518 - 2* 5W
16​
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25Always
16​
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25not active
16​
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25not active
16​
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25not active
16​
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25not active
16​
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25not active
16​
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25not active
16​
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25not active
16​
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26maximize
16​
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26maximize
16​
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26maximize
16​
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26
0​
16​
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26
0​
16​
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26
0​
16​
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26
0​
16​
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26
0​
16​
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26
0​
16​
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26not active
16​
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26Always
16​
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26not active
16​
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26not active
16​
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26not active
16​
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26not active
16​
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26not active
16​
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26not active
16​
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26not active
16​
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26not active
16​
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27maximize
16​
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27maximize
16​
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27maximize
16​
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27
100​
16​
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27
100​
16​
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27
0​
16​
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27
0​
16​
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27
47​
16​
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27
0​
16​
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 2736 - LED Kleinleistung
16​
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27Always
16​
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27Nebelschlusslicht wenn kein Anhaenger gesteckt
16​
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27not active
16​
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27not active
16​
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27not active
16​
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27not active
16​
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27not active
16​
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27not active
16​
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27not active
16​
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28maximize
16​
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28maximize
16​
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28maximize
16​
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28
100​
16​
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28
0​
16​
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28
0​
16​
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28
0​
16​
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28
31​
16​
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 280B
16​
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 289 - allgemeine Glühlampe 27W: auch H15
16​
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28Always
16​
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28Rueckfahrlicht
16​
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28not active
16​
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28not active
16​
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28not active
16​
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28not active
16​
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28not active
16​
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28not active
16​
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28not active
16​
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29maximize
16​
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29maximize
16​
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29maximize
16​
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29
100​
16​
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29
0​
16​
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29
0​
16​
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29
0​
16​
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29
32​
16​
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 291B
16​
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 299 - allgemeine Glühlampe 27W: auch H15
16​
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29Always
16​
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29Rueckfahrlicht
16​
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29not active
16​
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29not active
16​
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29not active
16​
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29not active
16​
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29not active
16​
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29not active
16​
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29not active
16​
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2maximize
16​
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2maximize
16​
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2minimize
16​
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2
100​
16​
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2
0​
16​
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2
0​
16​
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2
25​
16​
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2
45​
16​
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2
0​
16​
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 28 - allgemeine Glühlampe 12W
16​
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2Always
16​
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2not active
16​
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2not active
16​
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2not active
16​
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2not active
16​
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2not active
16​
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2Blinken links aktiv (beide Phasen)
16​
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2not active
16​
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30maximize
16​
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30maximize
16​
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30maximize
16​
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30
100​
16​
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30
100​
16​
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30
100​
16​
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30
100​
16​
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30
2​
16​
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30
0​
16​
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 3036 - LED Kleinleistung
16​
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30Always
16​
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30Footwell lamp
16​
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30Footwell lamp
16​
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30Coming Home oder Leaving Home aktiv
16​
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30not active
16​
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30not active
16​
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30not active
16​
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30not active
16​
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30not active
16​
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31maximize
16​
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31maximize
16​
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31maximize
16​
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31
0​
16​
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31
0​
16​
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31
0​
16​
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31
0​
16​
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31
0​
16​
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31
0​
16​
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31not active
16​
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31Always
16​
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31not active
16​
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31not active
16​
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31not active
16​
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31not active
16​
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31not active
16​
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31not active
16​
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31not active
16​
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31not active
16​
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32maximize
16​
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32maximize
16​
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32maximize
16​
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32
0​
16​
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32
0​
16​
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32
0​
16​
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32
0​
16​
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32
0​
16​
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32
0​
16​
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32not active
16​
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32Always
16​
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32not active
16​
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32not active
16​
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32not active
16​
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32not active
16​
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32not active
16​
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32not active
16​
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32not active
16​
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32not active
16​
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33maximize
16​
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33maximize
16​
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33maximize
16​
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33
0​
16​
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33
0​
16​
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33
0​
16​
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33
0​
16​
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33
0​
16​
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33
0​
16​
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33not active
16​
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33Always
16​
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33not active
16​
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33not active
16​
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33not active
16​
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33not active
16​
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33not active
16​
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33not active
16​
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33not active
16​
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33not active
16​
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34maximize
16​
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34maximize
16​
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34maximize
16​
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34
0​
16​
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34
0​
16​
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34
0​
16​
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34
0​
16​
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34
0​
16​
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34
0​
16​
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34not active
16​
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34Always
16​
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34not active
16​
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34not active
16​
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34not active
16​
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34not active
16​
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34not active
16​
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34not active
16​
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34not active
16​
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34not active
16​
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3maximize
16​
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3maximize
16​
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3minimize
16​
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3
100​
16​
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3
0​
16​
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3
0​
16​
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3
25​
16​
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3
46​
16​
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3
0​
16​
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 38 - allgemeine Glühlampe 12W
16​
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3Always
16​
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3not active
16​
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3not active
16​
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3not active
16​
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3not active
16​
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3not active
16​
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3Blinken rechts aktiv (beide Phasen)
16​
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3not active
16​
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4minimize
16​
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4maximize
16​
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4maximize
16​
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4
100​
16​
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4
0​
16​
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4
31​
16​
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4
0​
16​
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4
43​
16​
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4
48​
16​
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 49 - allgemeine Glühlampe 27W: auch H15
16​
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4Always
16​
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4Daytime running lamps
16​
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4not active
16​
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4not active
16​
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4not active
16​
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4not active
16​
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4not active
16​
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4not active
16​
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5minimize
16​
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5maximize
16​
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5maximize
16​
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5
100​
16​
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5
0​
16​
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5
31​
16​
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5
0​
16​
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5
44​
16​
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 54C
16​
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 59 - allgemeine Glühlampe 27W: auch H15
16​
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5Always
16​
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5Daytime running lamps
16​
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5not active
16​
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5not active
16​
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5not active
16​
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5not active
16​
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5not active
16​
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5not active
16​
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6maximize
16​
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6maximize
16​
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6maximize
16​
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6
100​
16​
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6
0​
16​
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6
0​
16​
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6
0​
16​
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 61A
16​
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6
36​
16​
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 611 - Abblendlicht
16​
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6Always
16​
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6Abblendlicht links
16​
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6not active
16​
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6not active
16​
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6not active
16​
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6not active
16​
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6not active
16​
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6not active
16​
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6not active
16​
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7maximize
16​
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7maximize
16​
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7maximize
16​
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7
100​
16​
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7
0​
16​
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7
0​
16​
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7
0​
16​
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 71B
16​
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7
40​
16​
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 711 - Abblendlicht
16​
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7Always
16​
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7Abblendlicht rechts
16​
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7not active
16​
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7not active
16​
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7not active
16​
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7not active
16​
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7not active
16​
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7not active
16​
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7not active
16​
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8maximize
16​
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8maximize
16​
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8maximize
16​
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8
100​
16​
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8
0​
16​
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8
0​
16​
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8
0​
16​
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 81C
16​
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8
37​
16​
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 810 - allgemeine Scheinwerfer
16​
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8Always
16​
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8Left high beam
16​
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8Lichthupe generell
16​
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8not active
16​
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8not active
16​
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8not active
16​
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8not active
16​
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8not active
16​
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8not active
16​
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9maximize
16​
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9maximize
16​
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9maximize
16​
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9
100​
16​
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9
0​
16​
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9
0​
16​
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9
0​
16​
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 91D
16​
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9
41​
16​
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 910 - allgemeine Scheinwerfer
16​
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9Always
16​
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9Right high beam
16​
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9Lichthupe generell
16​
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9not active
16​
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9not active
16​
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9not active
16​
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9not active
16​
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9not active
16​
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9not active
16​
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14maximize
16​
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14maximize
16​
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14maximize
16​
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14
0​
16​
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14
0​
16​
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14
0​
16​
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14
0​
16​
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14
0​
16​
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14
0​
16​
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14not active
16​
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14Always
16​
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14not active
16​
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14not active
16​
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14not active
16​
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14not active
16​
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14not active
16​
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14not active
16​
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14not active
16​
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14not active
16​
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1active
1​
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2active
1​
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3active
1​
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4active
1​
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5active
1​
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6active
1​
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typnot active
1​
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0
0.00%​
12​
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1
5.00%​
12​
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2
50.00%​
12​
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3
75.00%​
12​
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4
110​
12​
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5
126.5​
12​
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0
0.00%​
12​
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1
6.00%​
12​
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2
16.00%​
12​
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3
30.00%​
12​
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4
60.00%​
12​
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5
100.00%​
12​
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbaractive
16​
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten
4​
16​
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnungactive
16​
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbaractive
16​
ENG98831-ENG126848-Personalization-Personalisierung_aktivactive
16​
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbaractive
16​
ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0active
16​
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1active
16​
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2active
16​
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3active
16​
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4active
16​
ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5active
16​
ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6active
16​
ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7active
16​
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RStactive
8​
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierungactive
8​
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 100 00
20​
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 200 00
20​
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 300 00
20​
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 400 00
20​
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 100 00
20​
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 200 00
20​
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 300 00
20​
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 400 00
20​
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 500 00
20​
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 600 00
20​
DV52
Australia
@carbon_gecko :nothing obvious about the RHLS in the admap but some odd values in your Leuchte-sets . I suggest you change the settings as shown - bracketed values are your current settings:
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 > not active (Daytime running lamps)
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 > not active (Footwell lamp)
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 > not active (Coming Home oder Leaving Home aktiv)
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 >0 (100)
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 >0 (100)
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 >0 (100)
carbon_gecko
texas
2016 GOLf tsi 'S'
I'll try that later today and let you know, thx.
carbon_gecko
texas
2016 GOLf tsi 'S'
Thanks I changed those settings sadly no change to the errors
DV52
Australia
@carbon_gecko : No, my suggested changes were intended to address the double-speed turn indicator fault - they won't fix the RHLS issue
Don
carbon_gecko
texas
2016 GOLf tsi 'S'
Don
Yeah they didn't change anything. The double speed indicator is still present. Just got rid of excess.
carbon_gecko
texas
2016 GOLf tsi 'S'
wow, i have been waiting on the correct light switch forever! so i have installed the 5GM 941 431 B, cleared faults and it all works fine now
