Mother
- Orlando, FL
So ttrs calipers, ttrs rotors, ttrs brake lines, ttrs brake pads, and ttrs dust shield. Did I forget anything or is that all I need to do the swap?
That should be it. The calipers I got came with the pins and springs. If the ones you get don't then you'll need those. Some manufacturers include them with pads, but otherwise you can get the hardware set from zeckhausen.
Only other thing you'll need to decide is how you want to handle the wear sensor. You can code it out with VCDS or OBD11 or you can just snip the one off your stock pads and make a little jumper wire and heat shrink it, which is what I did. I think ECS sells a pre-made jumper also if you don't feel like making your own.
