YWWV, I hesitate to go this route because now you've altered the load path. Rather than transferring the load to the control arm under compression and only using the hardware for locating the joint, you're asking the hardware to take the load under compression. Something it wasn't designed for. You may be able to get away with it in a short term, but I'd be checking that hardware before and after every event (since your avatar indicates you've been on track). There may also be a change in roll center, but that's also based on ride height.I noticed this on install, and just ran them flipped (ball joint ontop of lca, rather than below, the bolts/nuts and such left same orientation), no contact (or other) issues.
I'm confused as to what's going on here. The normal position is to have the ball joint on top of the LCA. You're right in that flipping it would be a bad idea, but q74 seems to be describing the standard orientation?YWWV, I hesitate to go this route because now you've altered the load path. Rather than transferring the load to the control arm under compression and only using the hardware for locating the joint, you're asking the hardware to take the load under compression. Something it wasn't designed for. You may be able to get away with it in a short term, but I'd be checking that hardware before and after every event (since your avatar indicates you've been on track). There may also be a change in roll center, but that's also based on ride height.
I do like the other solution of slimming down the pad on the control arm. That is a good alternative.
Gotcha, pulled up my TT service manual and it looks like the ball joint is below the arm and the locking plate is on top. Whereas my whiteline BJ is locking plate, BJ, then arm. I dunno why having it on top of the LCA would be an issue if it fits. Just screws with your geometry.Normal for golfs/a3s but for tts it's the other way around. Here's a press diagram to prove it. Note the spindle shape as it provides a ton of clearance around the ball joint.
I followed in @MrFabulous footsteps today and took a couple mm of spindle off from around the ball joint retaining plate and now all is well. I think this is the only way to do it (my suggestion of filing a bit of the control arm itself wouldn't work since the retaining plate is the bit that makes contact/slices into the spindle). For anyone looking to do the same, a set of bits similar to these and a dremel is all you need.
Zero toe is what I run. No complaints.Got my alignment done properly, looking fwd to the first track day in a couple months to see how it feels. What do you guys recommend for toe? Large circuits, no autocross. Also don't want my tires wearing down too quick if it makes a big difference. TIA
Just ordered from e-acca, took 3 weeks or soyou finally found a set?
I have all the parts to do the swap but not ready to do it yet. Yes it will increase track width. Hence why I’m going to get wider guards first before doing it. Yes you need the matching outer tie rods. Also takes a different pinch bolt and nut.Anyone running TT LCA + ball joints + knuckles?
Is this combination confirmed to not increase track width? And are TT tie rods required?
I am very interested to see an alignment sheet with all OE audi front parts. I just went back to basically the CSS setup with camber plates, the simplicity sure is nice.I have all the parts to do the swap but not ready to do it yet. Yes it will increase track width. Hence why I’m going to get wider guards first before doing it. Yes you need the matching outer tie rods. Also takes a different pinch bolt and nut.
