Audi TT (8S) Control Arms
MrFabulous
Chicago, IL
2017 GTi Sport
Updating to where I am now in my quest. These two pictures illustrate the difference between the tapered insert on the GTI spindle and a TT spindle. The outer tie rod in both pictures is an 8J TT outer. The insert is what I can only assume to be galvanized steel since it does attract a magnet but hasn't suffered any corrosion from age. The steel insert would hold the taper better than aluminum which would loosen as used due to the soft metal. While it is possible to fit the TT outer tie rod to the CSS spindle, the taper engagement is not nearly safe enough and I do not recommend it.
What I ended up doing is to get a pair of TT spindles off ebay, removed the tapered insert with a simple ball joint press (about $50 on Amazon), and pressed the TT insert into the CSS spindle. Doing so will allow me to use all OE pieces in my assembly.
I did measure the insert and got a quote from emachineshop.com to reproduce the part. Such a small quantity is prohibitively expensive so for the small group of people who may be interested you're still better off buying used spindles and removing the insert.
I have no data on the extended inner tie rods from Hardrace. That could be the cheapest and easiest solution if there is a US distributor. But again, I wanted a solution that would use all OEM parts.
yakev724
NYC
2015 S3
Nice work, will follow in your footsteps this winter.
In the meantime chasing a very subtle clunk/creak since I replaced my ball joints + set to min track width. Only happens when I apply ~50% throttle and weight of the car shifts rearward (doesn't happen when accelerating gently). Will start with strut top mounts as getting a bit of creaking while turning near full lock as well... Sounds very similar to previous ball-joint induced noise though, just happens much more rarely.
MrFabulous
Chicago, IL
2017 GTi Sport
Not sure what I could be. I get a little more NVH from the new transmission mount bushings in the upgraded dog bone kit. I get occasional noise from the camber plates but it's tolerable. With the amount of upgrades done to the car so far it's going to make a noise or two. I will say I'm liking the setup better than the adjustable powerflex control arm bushings I had in the car before to add camber.
jamstonmartames
North East
GOLF 7.5
Hello Hello
I was inspired by this thread and have been collating parts for a while now, some new some 2nd hand and refurbing them. This is a working thread so bear with me on the parts.
The setup is a golf 7.5 r and the aim is to remove everything and employ the below setup
5Q0 199 369G Alu Audi MK7CSS Subframe
PART ID Alu MK7 CSS Spindle/Knuckle/Hub Assembly carrier/swivels (how many names for the same thing?)
PART ID Alu TT Lower Control Arms
PART ID Cupra/RS3/TTRA BBK 370MM
PART ID TT Ball Joints
PART ID Whiteline Sway Bar
Concerns from nuggets in the thread
  1. The LCA's are 10mm shorter than those of pressed steel 00Zero jdlavelle1975
  2. Using Spacers to offset the Brembo's on 19 prets will force the travel to hit the wheel arch liner @CZR @breakingbad however in my simpleton mind, doesn't adding spacers put the wheel back nearish to the pressed steel position? or is this a caster difference? @Yumichika
  3. This setup may limit me on the more extreme side of negative camber as oppose to a desired -1.3/1.4 ° ish @oozero @odessa.filez @yakev724
  4. Tie Rods aren't a perfect marriage and will have an effect on steering (still finding the quote for this one in this thread.)
  5. Sensor positioning for DCC may be tricky if using TT LCA's @CZR
Don't mock the colour. I had leftover upol lying around.
yakev724
NYC
2015 S3
V pretty. If you're planning on tracking you may want to replace the dust boots in those calipers with higher-temp versions as they have been known to perish.
jamstonmartames
North East
GOLF 7.5
Thanks for the insight. I might have to do this at some point.
Any advice with regards to the following or is it all going to work perfectly?🤭
  1. The LCA's are 10mm shorter than those of pressed steel @00Zero @jdlavelle1975
  5. Sensor positioning for DCC may be tricky if using TT LCA's @CZR @LeGti
q74
R
1. This info is wrong, with correct ball joints, they are actually longer overall and will increase track and camber.
2. Not sure what your refering to here? I will say that wheel fitment is extremely dependent on a large number of factors and camber gain methods (top vs bottom vs knuckle/spindle). What wheels are you trying to fit with which BBK and what spacers planned to use? Might be able to help with more direct information.
3. Not sure what the question here is? Minimum or Maximum camber? The mixture of the TT LCA and CSS knuckle/spindle with stock top-mount will basically set your minimum camber to somewhere around -2.0 to -2.5, unsure exactly, but your minimum camber with this mix will be high. I doubt very much you'll be able to get lower than -2.0
4. For what I think your attempting, the stock tie-rods will be fine. At minimum ball joint distance/camber, the tierods will be good, but if you want more camber/track-width from the bottom you'll need to start thinking about switching to hardrace "stance" tie-rods.
5. I did not have any issues with mine, but I've others did - not sure why. The sensors for DCC lined up perfectly for me, but measure before installing, drilling a small hole is trivial.
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
replicate
Downunder
So there is a way to make this all work well I believe. But you need to go all in. That is to also run the TT knuckle. A guy posted on FB that he fitted TT knuckles to his S3. He says that the TT knuckle runs way less (nearly positive) camber which offsets the added camber from the LCA. The benefit of the TTS knuckle is it has improved roll centre!! how much I don't know. You need to also run the TT tie rods as well due to the different taper on the knuckle. Annoyingly the TT knuckle is the same cost as the CCS units (expensive now) and I'm having trouble finding a second hand unit. But I'm keen to give this setup a go. Mainly for the roll centre.
jamstonmartames
North East
GOLF 7.5
So as @replicate, @odessa.filez @q74 have all pointed out, there are a lot of considerations to be had and as such have now found with all the pieces being mounted :)
Control arms (8S0407151D) are from a TT mk3
Ball joints (8J0407366/5R) from a TT mk3 (Febi Aftermarkets, some prefer Lemforder which is the OEM brand)
Alu Subframe (5Q0199369G) from a Audi S3
1LE -> Brakes (5F0615105/5) from an Cupra Leon R
Hub Carriers (5Q0407253/4E) from a GTI Clubsport S CJXG
1LD,1LE, 1ZA,1ZK Wheel Bearing (8S0498625) from a GTI Clubsport S CJXG
Racingline (VWR150002) Alu Specific (Torque /Dogbone /Pendulum and "whatever anyone else wants to call this thing" Mount
Whiteline (BWK019) Sway and Rod Pack (NB Anything bigger than 24mm on the sway thickness will hit the racingline mount above) Chamfering is required!
DD'S 12 and 15mm Hubcentric Spacers at 57.1mm so the brakes don't rub.
  1. So CSS knuckles will only fit if you mount them incorrectly; on top of the LCA as oppose to the bottom with the plate on top. @yakev724 found HERE that when flipping them over to the correct position the noises dissapeared. (To be expected if this is the correct way)
  2. TT knuckles are a must if you want to mount correctly as the CSS knuckles catch the end of the LCA's... fleabay search now begins, but as @replicate pointed out, tie rods may need to be changed as @MrFabulous has found out M12 vs M14.
  3. Running 1.7 negative either side which is less than the Cupra R ST (-2deg) is tracking from factory link, but toe running nearly neutral so tyres may actually survive :)
Will keep you posted but so far corners like a FWD Porsche.
yakev724
NYC
2015 S3
Only caveat to your post are any part numbers that start with 8S are TT mk3 parts.
That's exactly my setup now but with stock front sway, megane rs brakes, and pss10 with eurosport pucks.
Wouldn't mind changing for tt knuckles + tie rods but only if there's an improvement in geometry and someone else does it first!
jamstonmartames
North East
GOLF 7.5
I will edit it now ;)
jamstonmartames
North East
GOLF 7.5
Do you have your ball joints on top or below?
