Hi.
I have all the below mentioned mods. Had no problems during instalation. My car has stock spring and dampers with DCC.
Audi alloy subframe
Superpro LCA 0006K (ordered 0007K with less caster. But arms are marked with 0006K, so think I received the wrong part... Since I am on stock spring I have no rubbing with ekstra caster)
H&R ARB front and rear.
Superpro bushing all around.
Clubsport S swivels for added negative Camber
All the above installed parts went inn perfect.
No mods to the frame was needed.
I also have the torque arm and bushing from VWR. This had to be modified before installation.
Hi all,
I've been following this thread for a while now, and this is probably one of my favourite threads in this forum. I have plans to do what @LeGTi has done on my mk7R and I have a few questions...
1) I've read somewhere that people using the Supaloy arms with the alu subframe requires some sort of machining of the subframe? Anyone know if this is a myth or where that could've come from? If not, it's a simple "plug and play" install?
2) In regards to the Supaloy arms, I see in the thread that there are 2 versions...006 and 007k. Is the 007 an upgrade or are they 2 different things? 007 provides more caster but more rubbing due to increased wheelbase? any other differences between the two?
3) Would the superpro arms and bushings hold up to winter use?
Cheers!
Sent fra min SM-G955F via Tapatalk
