just look at the a3/s3 parts diagram.Are the part numbers of that controll arm screw's ( 7 ) N 106 959 01 and ( 8 ) N 106 403 01
is that right?
is that right?
@Pabo The A3 parts diagram I saw listed N 106 959 01. Check the link.just look at the a3/s3 parts diagram.
I have the TyrolSport deadset kit + aluminum subframe + washers.Looking to do this upgrade to my '17, per another post there's these 7 items -
I was considering the TyrolSport Deadset kit which I think would negate the requirement of those four (4) bolts from above. Could someone confirm the TyrolSport ones are sufficient for the Audi subframe on the MK7? I suspect the washers still recommended (they're <$10 regardless)
- subframe 5Q0199369G (x1)
- washers WHT006844 (x2)
- bolts N10785401 (x4)
Yes! Control arm bolts on the Aluminum subframe are 10mm longer!https://docs.google.com/spreadsheets/d/1JZzBmXWmrl-4BqCT4US33ct3Nc9DUjPyhsRitjYMRFY/edit?usp=sharing
Keep in mind you need different bolts for the control arms. They're longer on the aluminum subframe.
technically i think some of the other hardware is one-time use as well. sway bar/steering rack bolts, plus the dogbone mount bolts.Thanks guys! @DerHase , appreciate the spreadsheet as well. So we're looking at
- 1 x Subframe (5Q0-199-369-G)
- 1 x Tyrolsport Deadset (TSDSKVW7)
- 2 x Washers (WHT-006-844)
- 4 x LCA Bolts (N-106-959-01)
