Navi
- BK/NYC/Hamptons
I used red loctite on my USP studs. I asked a shop to try and remove them (because I have a weird issue with them that I might have mentioned in a previous post) and they said I would need to replace the hubs if I went through with it. Wish I knew about that high temp blue loctite!
you can still remove them. I've had red loctite on my studs and they've come loose on their own after a year, which is pretty normal considering I impact everything on and off at least 10x a year. I would be surprised if you can't remove them with just hand tools. A ton of dirt, grime and heat get into the loctite at that location. You can always use a torch to heat them up. Don't waste your time with any blue loctite. Might as well put water.
