I was under the impression that the USP titanium bolts are R13 ball seat and that your OZ wheels are R12 ball seat...
There is definitely a bit of confusing info on R12 vs R13 online as it seems most sellers just list "ball seat" as if they are all the same (including USP, but I assume theirs are R13 since they say they are for use with stock wheels).
I have OZ Ultraleggeras, which are supposed to be R12 seats and when I wanted black bolts for them the only ones I could find were from Otis. When I searched the part number they list to see if there are any other sellers and found it's the same part number ECS has on the lugs they sell to use with stock wheels. Based on that I'm thinking anyone with an ECS flush kit or black bolts is likely using R12 bolts instead of R13 on their stock wheels, which isn't supposed to be correct, but you don't hear of anyone having issues.
Oh ball seat bolts/nuts, I hate them. I don't care for lug bolts in general since there are so many more concerns than with lug nuts, but that's a separate post.
Ball Seat Radius' are something of a grey area with aftermarket lug nuts/bolts and wheel fitment, but really shouldn't be.
The radius of a bolt is significantly more complicated to forge and measure, and the differences aren't really obvious to the naked eye. Because the bolt has such a small section, you really need to see that seat carry out a fuller arc to see and easily measure the differences. It's not just the R number spec that's important, there is also the width of the seat that is going to affect fit in a given wheel, but the seat width has no correlation to the R number. Fun right?
Porsche for example uses an R14 seat like Mercedes. OEM Porsche bolts are also 1"+ wide at the seat. These bolts are not only the wrong radius for most wheels but they are likely so wide that the seat would only touch the very top of the wheel seat even on a R14 Mercedes wheel. If that seat was narrower in width where it could fit inside of a smaller diameter wheel seat even if the Radius was incorrect, it would make more contact with the seat. Maybe not "sufficient" contact, but that's difficult to measure without a lot of testing equipment.
What we're really looking at is torque tension and clamping force, which is the bread and butter of a wheel fastener. It's primary job is to clamp the wheel to the hub, and between the threads and seat, hold that torque in tension until it's broken manually. The better the seat of the wheel makes contact with the fastener, the higher that force, the better the wheel is held on, the less likely your wheel is going to beat you to your destination.
With ball seat radius' you need these elements to match to be ideal. If they don't match, is that immediately an issue where tension will be lost? In my experience no, and thankfully so. Even though the engineering side disagrees the physics have a bit of wiggle room for what ultimately holds. That's not to say that any OEM would play fast and loose with ball seat radius', but in the aftermarket ball matches ball with only a few outliers like Porsche.
Opinion here: Aftermarket Ball Seat wheels should only exist for specific applications to allow the continued use of factory fasteners. Period. What Neuspeed does uncomplicates this entire process by making a wheel that at the hub is effectively an OEM wheel. Same pad thickness and ball seat radius, so it uses the factory bolts. Awesome.
For every other wheel, conical seats should be spec'd. That eliminates an OEM only element that has many variations and creates a consistent 60 degree taper spec. Then all you need to be concerned with is lug bolt length, which is fun in it's own way to confirm.
OZ Wheels that use a ball seat, where I know Tire Rack provides a spec of 36mm under head length and an R12 ball seat radius, matches zero OEM specs exactly as far as I can find. Closest would be an older Mercedes application which had a ~40mm OEM bolt length and an R12 seat. That's vehicles with a year model prior to 2007. So except for someone rocking a 190E Cosworth, no one with a modern VW/Audi or MB with a 5x112 has fasteners that match that wheel. IMO, OZ needs to update that wheel!
