skinnyroots
- Toronto
I had a look in the owner's manual and it said to contact VW if you need a bulb replaced but I'd much rather do it myself. Are there any video tutorials or step-by-step guides floating around the ether?
You shouldn't have to remove the bumper if you don't have the xenons. The procedure of replacing a headlight bulb is written clearly in the owner's manual, at least on mine. and here is a how to video: https://youtu.be/M7RQqPKZz40
I spent about 5-7 minutes to replace left and right H7 bulbs on my TSI Estate/Variant directly from the engine bay, "the normal way". Very easy. It’s tight but far from impossible.
/Peter
PS @Fanis - Your video is about Golf 6 Estate .
I just replaced the low beams in my GTI. Thread in the Cosmetic forum. Found you can get a little more room removing the fuse box cover as well as the high beam cover. Doesn't get you a lot of room, but I have pretty big hands and it was enough for me. Passenger side wasn't too much of a problem. Recommend using a rubber jar opener for a little extra grip.
i was thinking of upgrading the bulbs too.. the stock ones are "C&%P" coming from xenons on the previous car, its like someone turning the lights out completely. Is it just one pair of H7 and H5 required? h5 for drl and H7 for dipped?
Can you provide link to those direction in the cosmetic forum?
