golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
Biggest weight saving by swapping only one item....replace the battery with a lithium ferro-phosphate battery "LiFePO4"
Below are the biggest case size (H6/096/Group 48) batteries, with the highest Ah/CCA, that you can currently fit to the Mk7 Golf:-
Bosch or Varta AGM, with 70Ah, 760A CCA, weight of 20.4Kgs (45lbs), cost circa £140
Antigravity LiFePO4, with 60Ah, 1800A CA, weight of 8.2Kgs (18.15lbs), cost circa £950
For reference the Mk7 Golf GTI Clubsport (CCS) is factory fitted with the smaller H5/027 case size, 59Ah/320A (DIN), EFB type battery (weight 16.9Kgs (37.3lbs)). The biggest Ah capacity Antigravity LiFePO4 battery in the same H5/027 case size has 40Ah,1500A CA, & weighs only 6.9Kgs (15.2lbs)!!
