StorableComa
- SoCal, USA
- 17 GSW S FWD
You have to flash to the stock file. You can run a swapped turbo on the stock file. Just don't beat on it, to set readiness.Damn really? So i have to put stock turbo back on as well? Where did you get this info?
CA is now a visual inspection, which with oem parts you should be fine. And and ODB2 ECU scan where they now check for tunes via the CAL ID and Calibration number.
So you'd either have to flash APR stage 1, or stock to pass the ecu scan portion and only after you set all your smog readiness monitors.
