APR Presents the IS38 Turbocharger Upgrade for the GTI/A3!
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
Product Page
APR is pleased to present the OEM Golf R/S3 IS38 Turbocharger ECU upgrade for GTI/A3 platform vehicles!
APR’s IS38 Turbocharger ECU Upgrade is designed for use with the factory Golf R / S3 turbo on GTI/A3 platform vehicles and produces an asphalt-shredding 386 HP on 93 octane fuel, and over 400 HP using APR’s upcoming Ethanol Flex Fueling upgrades! It's even compatible with the factory downpipe exhaust system, at lower output levels. Expect lightning fast response coupled with smooth daily driving and a much broader power band that pulls all the way to redline!
Using multiple vehicles across the world and in house, APR’s team of Calibration and Electrical Engineers spent the better part of a year mastering the factory Simos 18 engine management system to work seamlessly with the upgraded IS38 turbocharger unit. All critical aspects of the vehicle’s platform were taken into consideration and monitored through APR’s proprietary engine management logging tools to levels often not seen elsewhere in this industry. Through proper mapping, the ECU fully understands the hardware changes and operates correctly. As such torque delivery is smooth and flat, avoiding compressor surge, limitations in the factory fueling system, and limiting stress on the factory transmission. Cam phasing and valve lift operations are optimized, aiding in turbocharger spool, while allowing the engine to breathe more efficiently at higher engine speeds. Under various operational modes, lambda, ignition advance, requested torque, boost pressure levels and more were painstakingly optimized to produce maximum power without resorting to risky calibration shortcuts.
To APR’s Engineers, this is the ultimate pursuit of performance without compromise. To the driver, it just works!
POWER FIGURES
Graphs
With OEM Downpipe
Wheel | Crank | Gain over Stock - 91 AKI / 95 RON
Wheel | Crank | Gain over Stock - 93 AKI / 98 RON
Wheel | Crank | Gain over Stock - 100 AKI / 108 RON
Wheel | Crank | Gain over Stock - Ethanol
With APR Downpipe
  • APR recommends and tuned with Sunoco GT 260 for 100 AKI mode and Sunoco GT 260 Plus for 104 AKI mode. Never use lower octane than specified by the mode.
  • Ethanol software REQUIRES APR’s upcoming Ethanol Flex Fueling upgrades.
  • Max increases are based on APR's actual measured stock values and not those reported by VAG. | RON = ROW Fuel Grades | AKI = NAR North American (RON+MON)/2 Fuel Grades.
  • Reported wheel figures measured using APR's in-house Dynapack Dynamometer with a US Spec MK7 GTI with factory IS38 turbocharger, APR Cast Downpipe, APR Intake System and APR Intercooler, using SAEJ1349 correction and an average of multiple runs. Crank figures are estimated based on the measured wheel figures. Results may vary depending upon environmental conditions, vehicle, transmission, vehicle health, operating conditions, temperatures, fuel grade, dyno type, dyno setup, other variables and other modifications.
  • Race Fuel Information: Higher octane fuel typically allows APR’s engineers to create more power and torque by achieving greater ignition advance. However, on this application, APR’s engineers were able to achieve MBT, or minimum spark timing for best torque, on 93 AKI fuel with the APR downpipe. MBT is essentially the point where greater ignition advance no longer results in more power and torque. By using APR’s upcoming Ethanol Flex Fueling upgrades and Ethanol fuel, greater peak power was achieved due to the fuel’s highly oxygenated nature.
Requirements and Recommendations
APR’s IS38 Turbocharger ECU Upgrade is sold as software only. The factory turbocharger necessary for this upgrade is conveniently available at various APR dealers and VW, Audi and Seat dealerships across the world.
  • Turbocharger - An unmodified, OEM IHI IS38 Turbocharger is required. APR recommends using the latest factory revision (06K145722H as of Oct 20th, 2015) with APR’s Turbo Muffler Delete and recommends replacing factory one time use nuts, bolts, gaskets, and crush washers.
  • Intake - The APR Carbon Fiber Intake System is highly recommended. This setup is necessary to achieve the advertised power figures.
  • Exhaust - Upgrading the factory downpipe is required for the higher output downpipe software. APR highly recommends using the APR Cast Downpipe System as this system is necessary to achieve the advertised power figures. The factory catback exhaust does not need to be modified.
  • Intercooler - Upgrading the factory intercooler is highly recommended. APR recommends using the upcoming APR Intercooler system. This setup is necessary to achieve the advertised power figures consistently.
  • Ethanol Support: - APR’s upcoming Ethanol Flex Fueling upgrades are required to run Ethanol calibrations. No fueling upgrades are required for conventional gasoline.
  • Spark Plugs - Upgrading the spark plugs with Denso Iridium IKH24, gapped to 0.024" ±0.002" or 0.6mm ±0.05mm with a change interval of 10-15,000 mi or 16-24,000 km is required for engine longevity and safety.
  • Transmission - APR recommends the APR IS38 TCU Upgrade for maximum performance on DSG / S Tronic models. A clutch upgrade may be necessary on manual transmission vehicles.
  • Oil, Coolant and Lubrication - APR recommends using Motul oils, coolants and lubricants with APR's Oil Catch Can System.
Application Guide
  • Audi A3 - MK3 / Typ 8V
  • Seat Leon - MK3 / Typ 5F
  • Skoda Octavia / VRS - MK3 / Typ 5E
  • Volkswagen Golf GTI - MK7 / Typ 5G
All transmissions, drivetrains, and markets supported.
US Pricing
  • $699 - Existing APR Stage I or II ECU Upgrade Customers
  • $999 - New Customers
IMPORTANT PRICING AND AVAILABILITY DETAILS:
  • - No price difference between factory downpipe compatible software and APR downpipe compatible software.
  • - Pricing: Please contact an APR Importer for pricing outside the USA.
  • - Availability and ECU Compatibility: Stages, programs, and features may not be available for all ECUs.
  • - ECU Revision Notice: Multiple ECU revisions exist for each platform. APR software may be temporarily unavailable when factory updates are applied. An APR Dealer can check availability in person, or over the phone if the ECU boxcode/revision is known.
Where to Purchase
Please contact an APR dealer to purchase!
WhiteVulpine
Kansas
Even though those are mouth watering numbers, I've read multiple places that the stock clutch is rated to 350ft/lbs. At 403ft/lbs I would need to move to a stage 1 or 2 clutch which would be another 1-2k. That gets expensive quickly. :-(
gn4rwhals
Detroit, MI
My APR dealer quoted me $950 for Stage 2 back in April, so for $50 more I can get the IS38 software as a non-user of APR software on this car.
So theoretically if I already had APR software I would need to pony up $699 bucks? So by that quick math the IS38 software would cost me $1650 total in flashes if I went APR Stage 2 in the first place.
Glad I waited at this point, some of your existing APR customers are going to feel burned though.
GarabinS1
Grand Rapida, MI
Great! Can’t wait for spring to get here! What if you had an ECU tune on your previous platform (mk5) are you still considered an existing customer, and would you still be eligible for the discount?
805mk7gti
Socal
Am I correct in my thinking that if you already paid $700 for stage 1 and you want to upgrade to is38 tune it's another $700 for a total of $1400 plus tax and labor. But a new customer can go from stock to is38 for only $999 plus tax and labor?
Arin@APR
Auburn, Al
B8 S4, MK7 GSW TDI
Yes, that's correct. They are two very different products and we hope you enjoyed the stage one software! I'm just glad we can offer a discount for you at all. Can't really do that wth hardware!
805mk7gti
Socal
Well I actually had Apr stage 2 on my 2015 GTI but I took advantage of the $2000 loyalty and traded it in for a 2016 with PP. Would I still qualify for the $699 price when you guys are able to flash the 16's?
nis240sxt
H-town
Arin, can you give some more detail on the flex fuel upgrade (installation complexity, parts, price, etc..) so we can better understand if it's worth it for the ethanol tune. Thanks!
RjRacing
Philly
I think they are releasing this at SEMA tomorrow, so we will hear all about this soon!
worldacgti
getting this......
I can't wait.....at this level, our cars will be able to play with a lot of stuff.....summer of 2016 should be fun:)
