Arin@APR
GOLFMK7 Official Sponsor
- Auburn, Al
- B8 S4, MK7 GSW TDI
APR is pleased to present the Solid Shifter Cable Bracket.
Product Page
Through countless years of professional racing, APR Motorsport identified the factory shifter cable bracket system as a source of sloppy shifts, missed gears, bracket and bushing failure and even transmission failure. The factory shifter cable bracket is made from plastic with rubber bushings. Over time the bushings wear out, and during long races, heat can cause the bracket to flex and break. To alleviate all issues related with the factory design and not just some, APR’s Mechanical Engineers created the ultimate and final upgrade: The APR Solid Shifter Cable Bracket.
Key Points:
The APR Solid Shifter Cable Bracket is made from cast 304 stainless steel and eliminates the rubber bushings with solid, CNC-machined mounting points. The bracket and bushings will not wear out over time or fatigue under heat and prolonged use, minimizing the potential for transmission damage. With the play and rubbery slop of the OEM component removed, it’s easier to find gears. Expect the feedback from each shift to remain true and confident with a more direct and solid feeling.
Application Guide
Engines: Transverse 1.8T / 2.0T / TDI / 3.2L VR6
Transmissions: 6 Speed 02M/02Q MQ350
Part Number: MS100084
Price: $199.99
Product Page
Key Points:
- Addresses both issues with the OEM design
- Cast 304 stainless steel eliminates flexible plastic OEM design
- CNC-machined solid mounts eliminate rubber OEM bushings
- Removes play, slop and the rubbery feeling of the OEM part
- Will not flex, wear out and / or break under prolonged use
- Lifetime warranty
Application Guide
Price: $199.99
