wrongwheeldrive23
Sorry if this was already answered, but wouldn't a turbo this size/ stock downpipe, be pretty lag on pump gas ?
Need to switch tunes.
Maybe I missed this in the multiple threads but how does it work if you go full hog and buy the MPI kit? Are you limited to only running E60/E85 or can you run off of 93 if ethanol is not available? Do you need to switch tunes or does the ECU auto detect what you're supplying to it and adjust accordingly?
Thx
When you are talking about regular turbos the size has almost everything to do with how quickly it will spool. Yes on a tighter short track you want power as quickly as you can get it. Hell you always want power as quickly as you can get it. However if you go to a high speed track with long straights the larger turbo may turn in better times because of the higher speeds you can pull on the straights if you top end power is significantly enhanced.Oh well it’s not really worth going away from my stage 2 that has 400bhp and 420lb after spending a fair amount on hardware. The low end shove is very good on the IS38. In fact it’s probably the better daily car to drive without spending excess £’s just for bragging rights.
There’s an interesting article by John Barker in EVO Mag (One of the most established motoring Mags worldwide) here in the UK comparing two modified Golf R’s saying the lower powered quick spooling turbo’s R’s (450bhp) v 500 TTV5. It would appear the lower powered car was quicker on the circuit due to its quick spool.
Maybe APR could develop this turbo to work better than IS38 using stage 2 hardware to give a quick spooling 450bhp output that’s a direct replacement to the IS38??
Arin it looks like you missed his last question.With MPI installed, you can run any of the octanes. It just enables and gets more power when running the E85 tune.
The technology exists to have both a larger turbo and quick spool up but you won't get it for these prices. Some of the cutting edge stuff would be turbos with an electric boost helper to spin up the turbo almost instantly which means instead of the usual power curve of a standard turbo you get a power curve that is much more desirable.
Your IS38 is great, wouldn't make sense to move up to this kit because you have a GTI with IS38 and the gains may not be significant for you. For folks with R's and S3 etc that want more out of their IS38 they have the option of going MPI and E85 which should give them a good boost of power over the stock setup. This kit of course makes great sense for folks who have stock turbo GTIs. And importantly want to be able to get that kind of power and be emissions legal.
I’m running a APR Stage 2 Golf R and not a GTI.
Ideally I would like to have seen APR develop a ROW kit that gives circa 450-475bhp and 420-430lbs with a reliable good quality turbo. Many of the 500bhp units are very laggy and disappoint many here in the UK as a daily drivers.
