APR DTR6054 Direct Turbocharger Replacement System
Keehs360
Denver
Mk7.5
keep the IEv2
I was gonna say something. But I feel it’s too early to fuck with u. Plz let me know when an hour after your first coffee goes by. We can spar using three to four word sentences then. I will out diggs the diggs
CarbonDub
Did apr cover the flash or at least offset some of those fees? If u don’t mind me asking?
I paid nothing out of pocket, just handed me the keys back and good to go!
AeroRick08
Rochester, NY
2017 Golf R - Manual
Same here, all covered by APR. I had to make a second trip to the shop to get it flashed because my box code file wasn't built yet, so this kind of assurance is much appreciated when labor time could add up quick with early adopters.
ALSO for those doing the install themselves, not to turn this into a DIY thread but the wastegate calibration can be trouble if you don't do it before install with a 5V source. Once I got myself a good pivoting/extending inspection mirror, the right lighting, and a tiny 5mm wrench, getting to the square on the rod was relatively easy between the turbo brace and drain line. Just took a few turns and a couple tightening down attempts to get it to settle where I wanted it, around 3.75V
Oh and I tied strings to the end of my wrenches so when I end up dropping it, I don't have to pray I'll locate it like a couple bolts probably still rolling around my subframe... :ROFLMAO:
CarbonDub
Currently have covid and skipping roughly 19 pages since last time. Whats the TLDR about the new tune revisions?
They’re free (even labor), it’s ECU for IS20 platforms only, but TCU for 7-speed DSG platforms only (double check me on that), and I’ve had no time to test it because it was stop and go traffic all the way home.
I’ll be at the track to test it out and will post some 1/4 mile slips later tonight. That’s all I’ve got.
Zhars
ON, Canada
Pretty much identical..
I really don't think I'm crazy and there's definitely something weird going on. A stage 1 car according to their dyno graph on 93 has around 340whp. So if I'm running times and traps equivalent to that.. is it really killing almost 60whp up top if my IAT's are slightly higher? Hopefully with some dragy data and actual logs APR can help me sort it out, and benefit everyone.
That's roughly what stock RS3 do in 1/8. Think they dyno around 375
AeroRick08
Rochester, NY
Same as stock RS3??? Now that's slightly depressing. I mean I get that we're talking 2.5 I5 vs 2.0 V4, but I recall Stage 1 R pretty much going head to head in youtube vids... then again how does the 1/4 look vs RS3.
CarbonDub
First pass, not impressed - especially not the trap speed. Nowhere near 115 where I expected (at minimum) 😐
Acadia18
2019 Golf R
