APR DTR6054 Direct Turbocharger Replacement System
ChristopherNeil
San Diego
MK7 GTI
Took a screen shot of my readiness via OBD11 after a good drive. No idea if I even ran the test/request correctly, but this was it. If anyone can educate me, please do, but this seems like no bueno regarding emissions.
timmyturbo
earth
Audi S3
For me at least, most of the monitors set on there own after a some drive time. The monitoring of catalytic converter and O2 sensor I always have to force the test through obd11. Below is the procedure for that. I have a different car than you so some of the monitors you have don't apply to me (secondary air injection for example).
Under Engine->basic settings->Automatic test procedure. Ignore the "automatic test sequence" not available. Click the check mark, basic settings status should go active. While in park, while keeping foot on the brake, press accelerator to the floor. I don't recall the sequence, but RPMs will automatically go to say 2K for xx amount of seconds, then 3K for xx amount of seconds, etc. Once it's cycled through the ranges the test will end. Takes a minute for the whole test. The monitoring of oxygen sensor and catalytic converter should now be set.
Hope that helps a little.
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
@Arin@APR replies to this thread
I only ever load "subscribed" threads when they are bold, which are basically threads I've created. I don't even know how to see where I'm tagged, but if someone has a tech support issue, they can just contact our support team: support@goapr.com or 334 502 5181.
scrllock
MI
Pretty sure he meant not for GTI... all those 3 cars share the same engine.
TT usually has a weird boxcode but I'm surprised they can't flash their R file to an S3. If they come back saying it has something to do with emissions, ask why there are still people who can't set readiness on their files.
Arin@APR
Auburn, Al
B8 S4, MK7 GSW TDI
Only golf r? I saw this when I ordered the mpi here at work.
  • Supports E60-E85 with fueling upgrades (Golf R/S3/TT S platform only)
Correct. My post wasn't clear. Updated it.
MQBGOD
Clearwater, Florida
Audi s3
In the next two weeks once APR ships my MPI kit, I’ll keep an update on what the DTR can do on e85 APR tune vs EQT with a IE downpipe on both tunes. Precision raceworks drop in 305 pump, APR boost pipes and intercooler, APR HPFP. Tunezilla Haldex Spring on 17x8 Rpf1’s on RT660’s at Bradenton drag strip. Right now I’m running a 11.94 on stock fueling. I’ll keep this page posted.
