I'll reach out to them and post their thoughts. More or less throwing up more info for others wanting to do the same thing with the DTR.
It appears to be a Spulen throttle pipe
That's a tough one just because I don't have any great logs of this. I'd like to say I'm usually in full boost after 4k rpm. I'm seeing about 28-29psi max on my gauge after a pull.
I did reach out to someone that had a unitronic stage 2 car with the same menthanol kit I do. They currently have their settings to start spraying at 6psi, and have it fully spray at 13psi. The settings below:
Of course a stage 2 car will have a bit less boost, but I'll try these settings and adjust from there. One thing I'm curious about is how much boost can you build while in launch control? And do you want to be spraying during this?
