APR DTR6054 Direct Turbocharger Replacement System
Acadia18
2019 Golf R
Wow really? Awesome thanks so much dude!
Hope yall will like a 160mph run with no intercooler!
Just send it back to me when you're done.
riceburner
nice try PPNT
MK5 Best GTI
i'm just getting sponsorships left and right these days, first urotuning sends me free stickers with a purchase, now acadia lets me borrow a scan tool? This day is just getting better and better!
riceburner
nice try PPNT
MK5 Best GTI
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
timmyturbo
earth
Audi S3
The test our guys ran was IDE00553-Automatic test procedure.
While I appreciate the quick turn around on looking for a solution, what do those without vcds do? I have the obdeleven device/app like @riceburner, which doesn't seem to support this process. There are probably some more hands off users who wouldn't even know these monitors aren't setting.
Arin@APR
Auburn, Al
B8 S4, MK7 GSW TDI
This process should be run by the person checking emissions with the emissions equipment IIRC.
timmyturbo
earth
Audi S3
Correct me if I'm wrong here, are these monitors not set prior to going for an emmissions check? The emmissions center runs their check/ test and then these would be complete? I was under the impression these monitors would go to ready after certain drive cycle conditions, then when you would go to the emmissions center for the check, they hook up there "tester" and verify all the monitors have completed. Most states seem to allow one to not set. If what your saying is the case then there is no worry here, if these should be ready prior to, then that presents a problem.
Edit: to add I had an emmissions check in April. I checked all the monitors prior to going since I had just uninstalled a Cobb Accessport. I am almost certain everything was set completed or ready prior to. I looked at the print out from the test center and all applicable monitors showed "ready"
ZuMBLe
NY
Alltrack 6MT
You're correct, at least in my state. You need to show up with a "ready" car. Some of these tests need to be run under certain conditions, not when the car is sitting in the inspection bay.
