timmyturbo
- earth
- Audi S3
Man @Patrykd07 really called that shit blizzard coming. That's some Nostradamos type of shit.
..I'm sorry last one. I have to.Man @Patrykd07 really called that shit blizzard coming. That's some Nostradamos type of shit.
Way too early to tell what caused it. Not safe to assume anything.damn, DTR blew up a motor with only 45k? safe to assume this was their tune?
Sometimes it's not about what happened at the time of failure, but what happened leading up to it. It's possible there was detonation in that specific cylinder previously which either damaged it or weakened it to the point a simple low load drive could make it fail. I'm really sorry about your situation @CarbonDub. I really hope it gets worked out regardless of what happened.I'm no expert, but wouldn't it would be really odd for a tune to cause a bent rod while cruising at steady speed, low load? Wouldn't that have to be an issue with fuel or spark? In for updates. Sorry about your car @CarbonDub , shitty situation for sure.
I'd recommend sending to APR. Just send it to their support email. They know what the boost curve is supposed to look like.If you are looking for something to do, would you mind taking a look at my log From what I can see it doesn't appear there is a boost leak, but I'm a super novice at reading this. It looks like at full boost specified v. actual are about the same.
https://datazap.me/u/audia3/boost-leak-test-6722?log=0&data=1&mark=16
Who knows. Would be one hell of a coincidence though when the car hasn’t had so much as a hiccup running APR Stage 1 for over a year prior to this. Timing is completely uncanny if it’s not related, but still too soon to say.Damn, shit getting heavy here quickly.
Turbo install is coincidence and the rod/engine was always about to bust anyway?
