El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
okay... those have got to be the worst logs I've ever seen in regard to DATA the horrible bit/refresh rate of the system you are using to log mixed with the lack of parameters its useless aside from knowing its actual psi stays in line with its requests. During the actual pull you can only see 3 snapshots of data really @2700,4400,6600rpm's
at face value 27psi tapered to 23psi when they shut down (early) - the numbers look good.
the numbers from that XL on the same dyno - clearly had some issue though... cause an xl even only 27psi would make at min. matching number and if it was with a DP - no question higher peak tq esp. since peak would not have been really fuel limited with an hpfp.
