They should only fit in one direction, the lower nut goes on the inside of the sway bar and the upper nut goes on the front of the mounting tab.
The end links are the same for both sides, but the lower mounts are different and labeled which side they go on (FL and FR) so make sure they’re on the correct side. People put them backwards all the time.
Hope that helps
