Anyone using the Powerflex hybrid dogbone puck?
Total1
GG
15 GTI Autobahn 6MT
You have to remove the pendulum mount too. It's no big deal. Note the 2 bolts holding it in are different lengths. Make sure the right ones go back in the right spots.
Yes, you cut it out. Hacksaw like this works.
I bought new bolt for the dogbone. Do I need to buy new bolts for the pendulum mount or I can reuse them?
AceHammer
NY USA
2015 A3
Depends on if the bolts look like crap from driving around in salt. If they look good hit em with a wirebrush and put em back in.
Nineeightyone
2019 GTI | 2004 JSW
I don’t recall removing my pendulum arm. Just cut the insert, arm sits above it.
Yeah, I only had to cut out the bushing. One bolt out, new bolt in, torqued to spec. The bolt is TTY, so it's a good idea to replace it.
Total1
GG
15 GTI Autobahn 6MT
Thanks everyone for the info. Was thinking might as well replace the pendulum mount if I have to remove it. Guess I'll hold off on buying the pendulum mount lol.
Total1
GG
15 GTI Autobahn 6MT
Stock is fine once you go Powerflex. Get BFI mounts instead.
I just got the BFI engine/trans mount installed. I was expecting much more NVH when I got the BFI mounts installed paired with the 034 dogbone insert but I can barely feel anything. Will be putting the powerflex in this weekend along with the rear subframe harmonic damper.
adgainai95
Melbourne
Golf R wagon
I recently add powerflex standard insert and ebay pendulum arm to replace 034 lower insert only. idling and reversing is similar to 034 insert. However once A/C is on, it does add a bit more vibration on cold start. but when it gets warm, everything is smoother, no to little vibration similar. however car does performance much better than with 034 only
