GTI Jake
- Charlotte, NC
$800 install? Where at the dealer lol You guys all get beat to death on labor, it's like a 4-5 hour job max
I've been driving with stage2 on a stock clutch for around 6 months. My clutch started slipping in 5th and 6th gear when I floored it on day one of the tune. I drive balls out in gears 1-3 without an issue. On occasion 4 th gear slips. The clutch definitely does better in warmer weather. Your car will be 100% drivable on a stage 2 clutch. I've had cars that when the clutch went out they were literally undrivable. This is not the case for our car. Go ahead and flash Stage 2 and start saving for a clutch. You will have time to save up.
On the low end, the R and GTI's clutches can only handle roughly 40-50 more ft/lbs of torque then stock. But we have seen owners slip with as little as a 30 ft/lb increase. The clutches can not handle it. They are really designed (almost seems a design decision) for stock power only.
Lots of threads out there. Are there any specific ones people recommend that discuss specific clutch recommendations and such? May swap it before it even becomes an issue, especially if it would cost me less overall if I did (be able to retain stock flywheel, etc). Thanks!
