Charlotte.:R
- Charlotte
- '18 Golf R 6MT
Are they Leggera HLTs? What are the wheels specs? Thanks.
Yes, Leggera HLTs. 19x8.5 ET47
I was looking at 245/35r19 over 235/35r19 hoping it might give a bit more comfort . Whether 3.5mm would give any ?a 235/35/19 PS4s has a treadwidth of 8.5 and 245/35/19 has 8.6 so no performance gain to be honest
Is the rubbing up front? I'm running the same spec wheels and tires, Michelin PS4S though, and have no issues. I did do the "fender screw mod" a while back when I was running 18x9 wheels; if you haven't looked into that mod, take a look.I'm running 245 35 19 -19x8.5 et 45 on my winter setup and I can hear something rubbing on dips and bumps.
I'm running a Firehawk Indy 500 which runs slightly narrow for a 245.
Sent from my LG-H831 using Tapatalk
Loving the PS4S, no experience with the Indy 500 so I can't compare there. I'm on 19x8.5 +45 wheels. Stock height and I've not once heard or felt any rubbing. I had already done the fender screw mod up front, so that might be helping. So glad to be back on Michelins. I had some BFGoodrich sport comp all seasons on my second set of wheels - good performance for the price, but so damn noisy. The PS4S are on another level of grip and much quieter. Moving from 18" to 19" with these particular tires it doesn't feel much stiffer at all; thinking the extra bit of sidewall from the 245 width helps slightly. Okay... time to stop rambling.I have a set of Neuspeed RSe102 19x8.5 et45 , initially I planned on doing the same setup as @Pound and install Indy 500 tires bcuz they fit for him with no issues but now I'm thinking of doing PS4S 24/35R19, are the Michelin's the same dimensions that they will fit ? according to tire rack on paper it says they are..
@Spoolin what's your setup and what do you think ??
Nice, please share. I love the RSe102, still think about getting a set one day. I did end up adding a 5mm spacer in the rear (not on the car in the first pic, just haven't taken any new side shots). Never been big into spacers, but I loved the way the 18x9's I have looked flush with the rear fenders, could probably have gone with a 10mm.you have the same specs setup I'm looking for so it is good to know you had no issues and the PS4S worked well with it, I'm gonna pull the trigger on it then, hopefully I have the same results. and yeah I agree, I believe the 245 probably helps cushion the ride a little, that and it just looks aesthetically well
nahh no worries I can ramble on too, my gf says I'm gonna be that old man that's talking and you just nod your head too hahah
thanks for the reply and info ...I'll post pictures when it's ready
Depends on your wheel size/offset and perhaps the specs of your tire. I had no rubbing with 245/40/R18 once I did the fender screw mod up front. I was running 18x9 +45 wheels and my tires had a diameter of 25.7". I later added 5mm spacers in the rear because the inside sidewall was very close to the rear shock (this wouldn't have been a concern with 18x8.5 +45 wheels). I didn't notice any issues before I installed the spacers and they were really more for peace of mind and a nice flush appearance.245/40/R18 would these be okay for stock suspension? Hoping for no rubbing
