Would this tire size be ok for stock Cadiz wheels or are the tires too wide causing too much flex? Thanks
Those are 8in wide, right? If so, 245 is fine, as long as it isn't a tire that runs wide, like RT660 or something with a really soft sidewall.
What size are your wheels?
Stock 18" Wheel - Stock Suspension - 245/40/18 = Fits w/o rubbing
Stock 19" Wheel - Stock Suspension - 245/35/19 = Fits w/o rubbing
18x8.5 +45 Wheel - Stock or Lowering Springs - 235/40/18 = Fits w/o rubbing
19x8.5 +45 Wheel - Stock or Lowering Springs - 235/35/19 = Fits w/o rubbing
If you are lowered, anything wider than a 8.5 wheel or 235 tire and you are risking rubbing. Not only are no two cars the same, but neither are any two specific suspension setups. I've seen two cars with the exact same setup, one rubs and the other doesn't. You just have to test fit and drive the car. Also, different tire brands will have slight variances in size. Tire rack will say that the a Michelin & Continental Tire are the exact same measurements based on the size of the tire. Every single 235/35/19 tire will read the exact same measurements on their website, so you can't go off of that information.
I'm running - 19x8.5 +45 Wheel - Lowering Springs 1" drop - 235/35/19 and I have no rubbing at all. Have never rubbed even once.
I was also running a 245/35/19 on my stock wheels & suspension and didn't rub at all.
Enkei RR05-RR wheels18x8.5 +45 with Michelin Pilot Sport 4S
Neuspeed RSe102 19x8.5 et 45
Michelin PS4S 245/35/19
Fender Screw Mod
Factory Suspension
Just bumping this thread up looking for advice.
Currently on ED lowering springs 1" drop with 235/35/19x8.5 ET 43 (no rubbing)
looking for a new set of tires, and thinking of going for 245/35, will this setup rub?
I can almost guarantee you will rub with a 245. Pretty surprising you aren't rubbing the fronts over larger bumps with your current setup. Fender screw mod should help, but a 1" drop with a 245 is rub city.
Never rubbed with 233/35, and no fender screw mod.
ED comes with the reverse rake pads which I didn't use, currently, the rear sits lower than the front
yeah, 235. Nitto NT555 G2 (Crap tire btw)I'm thinking you meant 235/35.
No two scenarios are the same. You can't compare any two setups like for like. I explained this a page back (9).
Generally speaking, a 235 on lowering springs won't rub but MAY require the fender screw mod. A 245 will almost guarantee rubbing, but depends on the drop and tire.
