xXDavidCXx
- AZ
- 2017 GTI SE DSG
You should move to a spherical coaxial spring setup. I think the Vorshlag is okay, but limits the car's lowering potential with all the hardware.I'm considering upping the rear spring rates in my car. Still a bit pushy with the 400/575 setup I have now.
Regarding front camber, I was trying out the Eurosport offset inserts with the OEM mounts along with CSS knuckles. I thought it would be a good solution for a street driven car without any added NVH. Got about -2.6 degrees of camber which I was very pleased with. Unfortunately as I was worried about, the offset angle did result in an issue. It seems that the Ohlins supplied upper spring bearing has separated on the outer side leading to some bad spring bind. After a track day, the passenger side adjuster came loose and I've been getting a constant popping noise up front.
Now to decide if I should get go all in on some Vorshlag plates or give up on tracking what was supposed to be my practical commuter car... @Mini7 , with the Vorshlag plates the upper spring bearing is included correct? I couldn't find a replacement for the Ohlins bearing online (PN 25602-02). I'll contact 3DM depending on what I decide to do.
I was able to get pretty low with my cobbled together GC plate.
