Yes, still same codes about data bus missing message.Fault in 6C still present?
It feels like the camera cant sense the steering angle and does not display the guidelines due to it. Very strange.
Thanks, that issue is gone now.
Do you have any idea about why the guidelines are not displayed?
@ejje: I found 2 x EU Golf mk7's in my database with the same long-code string as each other on their factory fitted hex6C module (same Part No. as your module).
Try this:
- Existing long-code: 0173020163002017000048
- .......New long-code: 01730001E3002017000040
Don
That's very helpful, thank you. Then I will try to set them to not installed.AHK = Anhängerkupplung = towbar
Most likely ARA is Anhängerassistenten (EN: Trailer Towing Assistant = TTA)
ARA mechanical = dedicated articulation angle sensor in tow ball?
ARA optical = optical trailer assist?
Also found this:
Pretty much what you've said.Hello
i have installed a low rear view camera from stock in my golf 7.5.
anyone have seen this ?
https://www.carsystems.eu/vw-mib-re...lowline-camera-to-highline-camera,id2898.html
can be changed the camera into the emblem ?
in theory the instalación could be easy, cut and paste the wires, and only extend the two can bus wires to the quadlock 5f….
any sugestión? Thanks to all
Take it apart. Remove and replace. Put it back together.Yes…. But how change the camera in the emblem?
I personally buy it from a supplier called "vwmodule-de" on eBay. They also have a website, contact them.Do you have any link for this?
