Anyone fitted a highline reversing camera?
Reaper1
MK7 GTI
Not that I've seen
Well, in the adaptations of 5F Under Vehicle Configuration ive found RVC_video_input: FBAS
Is it FBAS in your cars? FBAS seems to be an adapter for installing a camera.(Not sure about it tho)
IWMTom
"IDE03471-ENG126143-Vehicle configuration-RVC_video_input, FBAS, 30"
If that's the adaptation you're on about, then yeah, it's set to FBAS.
Reaper1
MK7 GTI
Yes it is, thats a relief. my headunit came off a passat, so i thought the rvc settings might be different because of the area view.
Reaper1
MK7 GTI
Hey, I Installed everything today. the car recognizes the camera tho i cant make any coding changes, what can cause that? the camera came as a virigin( long coding 00000000)
Reaper1
MK7 GTI
Any fault codes?
6C Camera System Rear View
System description: RVC Compact
Software number: 5Q0980556B
Software version: 0231
Hardware number: -----------
Hardware version: ---
ODX name: EV_CamSysRVRVCPANAMQBAB
ODX version: 006009
Long coding: 0000000000000000000000
Trouble codes:
B201300 - No band end programming occurs
static
U101300 - Control module not coded
static
B201000 - No basic setting
static
Hardware number is ---- which is weird
IWMTom
ODX version: 006009
Trouble codes:
static
static
static
Dunno where you've bought this camera from, but it's been knicked from the factory before it reached the end of the line.
Very dodgy.
Reaper1
MK7 GTI
Update, Spoke to A Friend That Has ODIS. And you were right, it is not parametrized and needs someone with online connection to upload it.
Sent from my SM-G955F using Tapatalk
