Anyone fitted a highline reversing camera?
Arad_20
Figured it out!
When fitting the highline RVC, don't tell 5F it has an RVC in byte 19 - instead, go into adaptations and mark "BAP VPS" as activated, and "BAP VPS msg bus" as "comfort data bus".
I now have all the modes I'm supposed to have.
If anyone has any questions regarding fitting a highline RVC to the Mk7, hit me up!
By BAP_VPS you mean what I Marked In The Pic? And if so, why is it on databus infotainment if i do not have a reverse camera?
IWMTom
To summarize...
installation is the same as this pdf
https://carsystems.home.pl/instrukcje/golf7rvcde.pdf
Two Wires to the headunit, 6 and 12
A Wire for constant 12v
Coding: as the pdf but don't tell 5F it has an RVC in byte 19 - instead, go into adaptations and mark "BAP VPS" as activated, and "BAP VPS msg bus" as "comfort data bus"
am i right?
Four wires to the HU - you forgot about the CAN HIGH and CAN LOW wires.
Everything else is correct.
Reaper1
So, did the AliExpress wiring harness work with Highline camera?
Sent from my SM-N950F using Tapatalk
I am waiting for the camera, harness is in the car. When i get the camera ill update you guys.
Sent from my SM-G955F using Tapatalk
Reaper1
To summarize...
am i right?
If Instead of enabling the BAP VPS i will just do the coding for the lowline, will it still work bit i will not have the highline modes?
