2016R. Took all the precautions and made sure I installed this thing correctly even reaching out to Iabed owner prior to install to try to make sure I have the install down pat. Yes I used the plastic "tool" and yes I made sure i did not flip the lips, and yes I used the right sealant and amount ( i forget exact type it was 2+ yrs ago). Was a bit frustrated right now as car is exhibiting clutch slip in 4th and 5th at around 4k rpm. Telltale sign, seep hole i see under the car where trans case meets block has a oil leak. Which leads me to believe its the RMS. Clutch done at the same time was a SB Stage 3 Daily. My guess is friction disk has some oil on face to flywheel causing slip at higher gears.... Everything was fine up till now.... Note: I am pretty easy on the clutch and usually clutches last me 100k or much more on a normal setup. Although this is an aftermarket clutch I would expect at least 50k life from it..In addition clutch does not slip if car is babied, only slips if you have full boost (26-27psi) and I don't mean full boost in high gear with low speed.
I'm a bit of a meticulous person and would like advice on these questions:
1. if oil is impregnated on the face of the friction disk is it just worth changing out entire clutch at same time? I know $$$, but since trans will have to be removed to access RMS. clutch has less than 20k miles. I am afraid I will not get the max proper friction between disk and flywheel even after meticulous cleaning. (thinking oil impregnation on friction disk is slightly like a sponge or am I totally wrong?)
2. if it is not the RMS leaking then what else could cause leak seen at that location? PCV is a spulen V2 (did not need this impulse buy 1-2yrs ago). boost is kept at 26-27psi. I could change it out to an updated OEM PCV and just sell the spulen. I don't track the car and I honestly did not need it.
3. if some oil is on face of friction disk causing slip then wouldn't i feel it on say 3rd gear, or is that too low a gear to cause enough power to make the clutch slip? I don't feel any other odd slipping.
4. Could the clutch actually be slipping and RMS failure both? this oil seeping without touching friction disk. I was thinking this also could very real possibility. Chances of this happening is lower i say though b/c clutch was fine up till now and loved it.
Thank you for specific answers to my questions and suggestions you may have.
For peace of mind I'm leaning towards replacing clutch as well but haven't decided and NO I am not doing the clutch change myself again. going to shop. too much work for the effort for my sake. I'm a bit older and tired. ;-)
