Air suspension and DCC
Liland
Middle of Norway
Was testing a buddys A8L yesterday, it had air suspension that lifted and lowered together with the driving mode.
I know how normal aftermarket airsystems work, but is it possible to make them work with the DCC?
Liland
Middle of Norway
I asked on vwortex and somebody said that accuair had been thinking about it but it wont be on the market for a while
Avanti
UK
DCC affects the damping (springiness) rate of change, the air suspension would change both the springiness and the rate of change.
Liland
Middle of Norway
Yes i know.
I just want air suspension that is controlled by the dcc button ;)
16plus4v1
Rossland, BC
In theory the DCC shock should work with Air Ride, question is, when do the shocks/struts bottom out? The fronts would pose the only concern I would think. Based on my experiences.
Liland
Middle of Norway
Good point! Lowering spring producers often reccomend shorter struts when lowering more than 35-40mm.
Maybe it is possible to make strut tops that raise the struts 20-40mm?
