Air Filter "Snow" Baffle?
VWGTI
It's supposed to catch moisture I think? I'm not quite too sure what it does either.
TheSwede
Sweden, Halmstad
Golf7 Alltrack/Cupra
Is it really designed to exclude snow? If I remove it, does the element still lay where it belongs?
I haven’t seen any official name on this grill. Could “snow guard” be a guess made up by this forum? My guess is that it’s a muffler. Had one on my former Golf 6 GTI as well.
You can do without it.
When I removed it I broke mine in one corner. The spare part price was about 10 USD / 10 EUR at the dealer.
/Peter
shep13
North Pole
Does anyone have a picture of this thing? I'm still waiting to take delivery of my car so I can't check myself.
Sent from my SGH-I337M using Tapatalk
Scottmk7
Here you go.
Sent from my SM-N910T using Tapatalk
Scottmk7
Thanks! And where exactly is it located?
In the air box under the air filter. So you open up the top of yor air box and take out the air filter and it is sitting right there.
BxGTI
Bronx,NY
/Peter
Snow screen is the official name
defcon5
TX
My MK3 1995 GTI VR6 had similar snow screen. Went into the trash bin 2 days after I purchase the car. Eventually traded that in for an A4 in 2002 after 140K miles
St. Olaf
In some VW literature it's called snow screen (ELSA, Erwin), in some it's called grille (ETKA).
I don't know if it's really meant to absorb any snow. Well, of course it could. In that case,
"hot climate versions" would probably come without it. It doesn't neccessarily need to be
true, but at least I've remember reading "somewhere" (VW literature, probably SSP or similar),
that this grille is aimed at distributing the airflow over the entire area of the filter element.
Either way, it definitely isn't a muffler. A plastic grille cannot effectively dampen any noise.
Removing that thing you probably gain nothing. If you want unrestricted air flow, get a new
filter element regularly (say, once a year). It's quite cheap (Mann, Wix, OE VW).
Great info btw.:
http://www.golfmk7.com/forums/showthread.php?t=7514
greggles
usa
GTI
Quick fix if you remove the snow guard to allow for even filter distribution.
Rotate your filter 180 degrees every half service interval. Easy peasy.
