rfc89747
- Pennsylvania
Today driving home from work in 90F ambient temps, I noticed my interior was not cooling normally. I have the dual climate control and set both sides to sync at 68F. The blower speed never decreased on my 40 minute commute. I could feel normal cool air coming out of the driver side vents, but the passenger side was barely cool/slightly warm air.
Has anyone had this issue before? I tried pulling over and restarting the car, but that didn't seem to change anything. I also tried max ac, de-syncing and setting the passenger side to cooler than the driver, and changing to foot well only. No change.
Edit: Update on this. I just tried the vent re calibration (hold middle vent button and AC button). It did it's thing, but didn't correct the issue. I scanned for fault codes using obdeleven nothing found. I used the output test options and ran a few of the flap tests which all seemed to be working normally. Following those tests the air seemed to be coming out equal on both halves of the cabin. It may have just been because I was parked in the shade and things were cooling down, but I did kick it into max AC and it seemed to cool evenly. I parked it in the sun, and will check it again in about 30 minutes. I also noticed a hissing sounds coming from the vents when I shut the car off.
