El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
close to the spring perch/mount in the fronts?Idk I didn’t do any more to get them that far in really, my camber plates go upto -6 degrees had them built specially for me ( neo Motorsport coilovers ) and I know in terms of poke but with the camber here extremely close to my perches so I’m worried anything more rhan 215 is gonna cause some serious rub
did you click the link i sent? i set it up with your specs - if you go from 9" at15 to 9.5 et 20 the wheel edge is only 1.3MM closer to the strut - even if you stuck with 225s due to the added stretch the tire sidewall will be farther away from the strut than even your current set up is.
