What did you do to reduce the poke? I'm looking for ideas for reducing the poke on 19x9 Et35 with 235/35 or 245/35 tires (the picture is with a 235/35 tire)255/30 on 19x9 et 40 all around
Get camber mounts and lower on coilovers. I doubt the oem struts (even dcc) will have stiff enough rebound to keep you from fucking up your fenders/liners.
On a 19x9 +35 with a 245 tire? Doubt it.
Not my car, so do whatever.
You think racingline springs will work?You just need to go lower and it will sort itself out. You have monstertruck fitment right now causing the "poke" look. If you go lower the wheel(s) will camber in and youll be g2g!
Honestly if I were to start over with the whole “aggressive wheel/ stance thing”..I would just go for coil overs my man. Springs are a waste of money imho. Most will only drop you 1.5 ~ 2.5 inches max. Obviously coil overs come at a cost but once installed offer 10x the adjustability (from dampening to camber adjustments if you buy the right sets).You think racingline springs will work?
