Euromistake90
- Denver
Alzor 020 gunmetal. They are BBS LM replicas made by AlzorLooks great... What wheels are those? Thanks
Sent from my SM-G950U using Tapatalk
Just right imo
On a 19" wheel? Not a good idea. Also coilovers are built with shorter bodies so they have normal suspension travel at lower heights.235/40. Raise your car a bit and get some actual suspension travel. Get some spacers and the fender gap will vanish.
Depending on the tire and ride height a 235/35 on that wheel setup isn't impossible at all. A 215/35 on that setup would give clearance for a tucked setup but shouldn't be needed for any suspension with space between tire and fender.I'm sure it may have been addressed here before... I have 215/35/19 on my 19x8.5 ET45 wheels. I'm lowered quite a bit, kind of want to go a little lower if i can but not necessary. Now, these tires are waaaaay too low profile. They came with the wheels. What would be an ideal tire size for this setup? Really don't wish to rub, I drive a lot! I'm on coilovers but would prefer not to raise the car. I'd love to close what little fender gap I still have, too.
Could I get away with 235/35/19?
Sent from my LG-H931 using Tapatalk
It's a pretty common spec... You should be okay depending on the ride height you end up with and offset.I don’t want it tucked up. The guy I bought the wheels/tires off of had them on a bagged car, hence the rubber band tires.
I just need some more meat. I guess I’ll try 235’s and if they rub, deal with it then. I’ve always had coilovers on my cars because with my first VW, I went through wheel/tire setups like underwear. It’s just been a long time and seems to be a bit more complicated on the newer cars. Plus, back then we just stretched the smaller tire onto the widest wheels we could haha!
Example:
I don’t think there is a need for or room for spacers from what I can see. I think if I spaced them out they’d just rub all day long. The offset looks great, in my opinion. I just want to crank the fronts down a little bit and also have wider and subsequently slightly taller tires.
Thanks for the input so far. Does anyone have pics of 235/35/19 on 19x8.5? I tried searching but didn’t find much.
Sent from my XT1806 using Tapatalk
Do you have a better picture of your current ride height? It's tough to see based on how dark it gets between the tire and body line.Offset is et45
19x8.5 +45 is a very common spec on these cars. Most run 235/35's and use a small spacer in the rear.Offset is et45
