Aftermarket intake with dry filter?
Faceman
Long Island
'17 GSW 4Mo
Other than the AFE intake, I'm having a difficult time finding one that includes a dry filter. The VWR R600 is interesting, but how well does a foam filter work compared to your typical dry filter? I understand the HP gains are almost nil, I'm just looking for a little turbo noise.
Thanks.
TwinDad
Fort Lee, NJ
You can always just do a drop in filter, remove the snow grate and cut out the grill vents up front. Then just do a turbo muffler delete and maybe a cts turbo intake. This will give you the noise you want and probably cost the least. Also will flow just as good as an aftermarket
Slick99
Karachi, Pak
i have done this mods in my A3 1.8tfsi, turbo sound can be hear from outside and slightly better acceleration response.
ltktw
Taiwan
MST Performance air filter adapter for R600 intake
Coming soon
mcl_sean
East Coast
MK7 GSW S 4Motion
Have an S&B with dry filter option, really happy with it. Closed system though so not much in the way of increased intake noise.
Sent from my SM-G920V using Tapatalk
Thrawn
SoCal
The Neuspeed intake can be had with a dry filter... I usually install the dry filter when I need to clean the wet/reusable filter... Swap back when ready...
yirayira
Chicago, IL
2015 GTI SE
Buy intake that uses a K&N filter. Then ditch the K&N and go with something like AEM Dryflow (which is owned by K&N).
Good call. I also added one of the water-resistant covers which should keep the filter cleaner for longer. Same fun whoosh
jackalope
Austin
The stock paper filter has a surface area of 27 square feet because it's big and has very deep pleats. A foam filter is only going to be about 1 square foot. Think of how big the pores have to be just to make up for that surface area deficit. Filtering is awful with foam filters
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
I have the VWRacing one...actually from the makers (ITG) with their branding...& its tri layer foam & with the thicker road oil....well tested & very impressed so far...I have used both K&N & Green Cotton filters in the past & never had any problems with filter oil...BUT I would leave to stand in a warm place for 24hrs after oiling & removed the excess oil...BEFORE fitting...
