Same..lol!If you have keyless, don't walk away from the car with the keys while flashing. Ask how I know. Luckily, recovery mode worked and didn't brick my ECU.
Make sure the charger can handle 20 amps. The car pulls quite a load when its flashing. Old style battery chargers can't handle the load. (I had to buy a new unit just to hold charge while flashing, most normal ones max out at 10-12 amps)
I did exactly that.
Did it brick your ECU also?
basic ecu/dsg tune on these cars is so much fun. EQT's dsg tune is amazing too, Ed does a great job with these cars. if was a more exotic setup (like SD tuned procharged c5z etc) then maybe dyno tune would be much better but a base stage 1 or 2 mk7 is so normal that Ed has tuned so many of them I doubt he has to do much work on the tables to fill them in so I'd be surprised if a dyno tune gained much more than a few hp max on a stage1/2 mk7 vs his normal ots tune or a street tune. I personally would just use the EQT ots tune and not do either dyno or street tune until you upgrade the turbo. may gain a tiny bit of hp but the gain not worth the hp or time. better places to put that $ to make real gains (like an EQT turbo or IE intercooler etc)
as you can see, the modified stock intake flows rather well!I've been eyeing the IE air intake (https://performancebyie.com/collect...systems/products/ie-intake-vw-mk7-audi-8v-tsi). I saw a thread somewhere and a couple folks interjected about the actually airflow not being any higher than the stock air intake? Anyone have any facts on that? Save me a search perhaps? Let's say it doesn't at all, where does the extra hp come from? Is there extra hp? I love the sounds but I don't wanna spend 300$ for sounds.... Or do I? Lol. Idk! I might need to just stalk the classifieds on here.
Just wondering,.
-Thanks
??. Thanks for that link! So it looks like we're only taking about ~60cfm more from the top of the aftermarket intakes. They were also in conjunction with an aftermarket inlet.as you can see, the modified stock intake flows rather well!
http://mygolfmk7.com/best-mk7-gti-air-intake/
If you search that site he has intake comparison tests with OEM inlets as well. The page I linked is a comprehensive test.??. Thanks for that link! So it looks like we're only taking about ~60cfm more from the top of the aftermarket intakes. They were also in conjunction with an aftermarket inlet.
Ed at EQT has said an aftermarket intake is worth maybe 10-15whp once you get to ~450whp level, so at the 300whp-ish level probably worth 2-3whp tops.
