WadeRoberson
- NA
- NA
My tires in the front are pretty much completely worn (the rears have about half their tread life left) and need to be replaced very soon, however since I planned changing wheels eventually as well. I don't want to put expensive tires on the 7.5" wide stock wheels and be stuck with stock wheels for a while. The problem is that I cannot afford new wheels and tires on all 4 corners (~$2k). I can afford new wheels and tires in just the front however. Is this actually an option? Would running different wheels and tires mess the car up in any way or would it be totally fine (other than looking odd)? Should I just get cheap tires to replace the badly worn ones while i save up for a performance set up on all 4 corners?
Heres the wheel & tire combo btw:
RPF1 18x8.5+40 ($300 each)
MPSS 255/35 ($230 each)
