For the couple (few, many?) folks with this mod, how's it holding up? Anybody had inverters fail on them?
Continue reading only it you don't mind rambling, you've been warned...
I've got my door panels off right now doing all of the things I have been putting off; sound treatment, replacing speakers, this mod, door exit/warning lights, Jetta door stops, blah blah blah.
Thought I bought everything for his mod over a year ago and finally unboxed it last night. Realized I bought the 3 volt power supplies (that take AA batteries). I have the 12 volt inverters on the way. Per the instructions in this thread these EL strips will be tied to dimmer control so will be on, and adjustable, when headlights are on.
Did the coding for the exit/warning lights and saw that "ambient lighting installed" is not selected in my door module long coding. This is correct, car is a TDI S and didn't come with anything fancy. Highline door modules were installed with power folding mirrors. For the warning lights I didn't even have to tap into a wire at pin 16 of the 32 pin connector, there was nothing there, lol.
But I started thinking that since my car clearly didn't come with ambient lights, and these EL strips will be my ambient lights... Can they be pinned elsewhere on the 32 pin connector instead of tied into the gray wire at pin 4? And then controlled via ambient lighting section of the infotainment?
I have no idea how stock door panel ambient lights work in the Mk7s that have it, never been in one. I also know that even if I find the appropriate pin I still need to figure out what the door control module output is; 3/5/12/variable DC voltage, AC voltage? Anybody know this information already before I spend time digging into it?
My inverters will be installed with quick disconnects to make replacement simple should one of them ever fail. So most likely I will do this mod exactly how it's written in this thread for now but I will look into the ambient lighting angle and report back at some point. Quick disconnects will make changing the power source trivial should I ever figure it out.
