add power folding mirrors to 2019 Golf R
FlintTownBrown
MI
2019 Golf R
I want to add power sideview mirrors to my 2019 golf R. I searched a couple forums and it appears i only need the housings...all electrical & switches, etc are already there? From what i've read, this appears to be the correct part by new part number 5G1857507DM9B9. There's an ebay seller with this ad: https://www.ebay.com/itm/Genuine-Ex...f-R32-Gti-Rabbit-5G1857507DM9B9-/202280807785
always leery of ebay stuff. ad says *VAG Genuine Parts* but i'm thinking this is the chinese stuff i've read about. Anyone familiar w/ this one?
i appreciate any insight. thanks!
ecsta
Toronto
2017 R
Get from e-acca will be the cheapest (although takes a little longer), parts should be the same just probably a newer revision, previous threads would still be helpful.
Lager_Ace
British Columbia, Canada
2017 Golf R
e-acca (y) That is where I got mine from.
Lager_Ace
2017 Golf R
Thats the correct #(y)the other # VAG 5G1857508FH9B9 from e-acca, suggest ordering extra door card clips VAG 7L6868243. You need a different switch to manually fold them #VAG 5G0959565AGICX then code them with OBDEleven or VCDS I used this DIY was pretty easy to install.
StorableComa
Long Beach, USA
17 GSW S
They could be China VW OEM. Though if you absolutely want OEM, e-acca or cars245.com will normally have the cheapest prices. Shipping normally takes about a month once they receive the parts themselves - which is normally within a week or two if you select Fedex at checkout. You'll get an email from Anna or Natlja updating the price with shipping a day or so later, it's normally 20ish bucks unless you're ordering something big/heavy/cumbersome. If swapping to dynamic turn signals I'd suggest doing it while they're off the car.
Depending on your R trim you may just need the mirror housings themselves and the folding mirror trim mirror switch. I went with these as I was looking more at cost over OEM, no issues so far. Though with my trim I also had to upgrade the door controllers as I had low line controllers with no memory function and no controllers for the mirrors.
https://www.aliexpress.com/item/32843343512.html?spm=a2g0s.9042311.0.0.27424c4ddGM6Aj
Turn signals: https://www.aliexpress.com/item/32877964009.html?spm=a2g0s.9042311.0.0.27424c4ddGM6Aj I went with these as they return the clear plastic for mirror side flash.
VDubberinDE
Delaware
2018 VW Golf R
Go with e-acca. You must be sure to get the ones with DAP, it comes in 2 flavors, so I would not go off ebay, just asking for issues.
2 years ago e-acca, it was only 163.00 per mirror when I bought them (I'm sure they have gone up but its factory VW parts).
This is a link to my install
Lager_Ace
2017 Golf R
I got them this year in March from e-acca $143 US each $28 for the switch $341total.
Lager_Ace
2017 Golf R
Good job on your DIY install (y)😊
GolfR-BA
Bay Area
Lots of good info here, thanks to all who posted.
Can someone confirm if the power folding mirrors impact the mirror dip? My 2019 R has the mirror dip but no return issue. I thought I read somewhere the power folding mirrors also allow the both the dip and return? If not, I have the info on the control module...
TIA for any info.
Lager_Ace
2017 Golf R
TIA for any info.
No it doesn't impact them and I didn't have to change the coding , they dip and return like the old ones.
I still have to manually adjust after every 10 dips or so due to there is no memory but no big deal.
Cheers (y)
FlintTownBrown
MI
2019 Golf R
awesome DIY vid. thank you for the link and all the info.
FlintTownBrown
MI
2019 Golf R
ebay Seller oe245 is actually a very reliable and fast seller, who sells only real genuine parts. I had very good experience with them.
that's good to know. thank you!
FlintTownBrown
MI
2019 Golf R
thank you for the info, and for the link to the dynamic blinker. i'm wondering what the clear version looks like, on the car, compared to the smoke black?
