i guess i don't really know what your full mod list is
Here's what would potentially be parted out:
Standard Housing Vortex w/ Calibrated Actuator - Less than 3k miles.
Autotech HPFP installed in OEM Housing - I'm the second owner, was told 10k miles on the internals when I bought it. I've added maybe another 1k. No idea on how many miles on housing.
Precision Raceworks Stage 3 LPFP - The Walbro 450. Installed in a drop in basked from PR.
EQT 5 Bar TMAP & 4 Bar PUT Sensors.
Accessport with DSG Flashing - With more tunes than you can shake a stick at, both ECU and DSG.
Majesty FMIC Twintercooler - The updated thicker one.
Racingline VWR R400 Intake, with ECS hose & CTS TIP.
A full Macan Brembo swap - Powdered coated red, currently with high temp 'GTI' decals. Technafit SS lines. Stoptech drilled and slotted front and rear rotors (non-PP rears), Power stop Z26 street pads for front and rear. All gotta be matchy- matchy. Whole setup looks bitchin'.
AWE Track Exhaust with the Brain Resonated Midpipe - Have both black and chrome tips for it.
Helix Euro MK7.5 Sequential Taillights, with harness.
EZ Retrofit Digital Dash.
8" Non-Nav Glass Screen, with piano black trim - There is a little chip on the very bottom edge, that you can barely see. I have a glass screen protector on it currently, and you can't see the chip at all.
Capacitive Climatronic Unit, with trim and harness for a retrofit in a non-climatronic equipped car.
Piano Black Trim Kit - Perfect for someone who installed the 8" glass screen and has been lying to themselves that it looks good clashing with the honeycomb GTI trim. Has the shifter surround, cubby door, non-climatronic control trip, and drivers side vent. All that would be needed is the gauge cluster trim.
Nothing is set in stone, like I said before there's a lot of variables in play. But if anybody wants to call dibs on things just in case it goes that way, let me know!
