Acadia18
- The Greater Boston Metropolitan Area
- sterkrazzy's exotic
Those are the 600 dollar zhongs, bmp just buys them, “QC’s” and then resells.
I was almost burned at the stake last time I suggested that.
its def true thoughI was almost burned at the stake last time I suggested that.
they are probably hella easy to retrofit though...Tiguan won't get upgraded lights. Best I can do is better bulbs.
Your mistake was implying they qc them at all.I was almost burned at the stake last time I suggested that.
Bumper removal required. If it's anything like pulling the GTI bumper though, really not a bad job at allthey are probably hella easy to retrofit though...
I have been looking for something to clean the tires so the P&S Undressed sounds like a good bet.Ran out of Adams Tire and Rubber cleaner which so far has been the best I've used so I ordered that last week, for the price if it works as they say is should be a staple from now on.
I know almost nothing about foam cannons other than I think I want one.I haven't. The general consensus is that most stuff from P&S is pretty good, so I'd expect both those to work well.
Do you think this shampoo would be good for that use? What makes for a good shampoo for a foam cannon?
What about for soap use? Didn't @Maiden69 say the MTM uses like half the soap?It says it's a foaming soap, so I don't see why not.
If you don't want to spring for the MTM one, this is the one I had before upgrading.
Tool Daily Foam Cannon, 1/4 Inch Quick Connect, Power Washer Foam Cannon with 5 Pressure Washer Nozzles,1 Liter https://a.co/d/gmGfjtW
The MTM is definitely better, but that gets you like... 90% of the way there for 1/4 the cost.
