How long did it take you? This looks like a bit of a nightmare and I have acc. I can buy a hella condenser for £85. I will get a price from my garage for fitting. If its silly money I might just leave it as I stay in Scotland and I'm lucky if I use the ac 3-4 times in the summer.
I've taken my bumper off several times so for me the install was quick and easy. If it's your first time it will take a little while but it's really not hard. I imagine it will be expensive if you have a shop do it.
Either way, because of the ACC radar you'll have to take the crash bar off. Unplug the sensor and get it out of the way beforehand so it doesn't get messed up. The good part is you can remove the condenser without going all the way to the intercooler so you don't have to remove the yellow clips that are a pain in the ass.
Removing the condenser is easy, disconnect the two coils and remove the o-ring on each one. Make sure the condenser is properly drained first! (If you had a leak, it will be). It is important to replace with brand new o-rings, lube them with PAG oil first.
I've heard conflicting info in whether or not to add oil to the condenser, probably be ok if you don't, but I added 2.5 oz. Then took it to the shop where they did a pressure check, then vacuum, then fill with freon.
Sent from my Pixel 2 XL using Tapatalk
