Perhaps I have found the answer fault code shortened to B109E
Climatic _-_-_-_-_-_-_-_-_-_-_-_-_-
Coding
Coding information is found using the*Long Coding Helper*while connected to the vehicle with VCDS.
When replacing a module it is recommended to save the original coding and transfer it to the new module.
Basic Setting
Note:*The basic setting needs to be performed, when the Climatic control module (J301) or flap motor(s) have been replaced.
Adapt flap end stops
Necessary when flap motors are replaced -or- when a self check needs to be performed for self diagnosis of faulty motors.
[Select]
[08 - Heating/Air Conditioning]
[Basic Settings - 04]
Select "Adapt flap end stops" from the drop-down list
[Go!]
The basic setting takes approximately 20 seconds.
Finished Correctly should be displayed
[Stop]
[Done, Go Back]
[Close Controller, Go Back - 06]
AC Compressor First Run-In
Necessary when the Climatic control module (J301) is replaced.
Prerequisites*to start the basic setting A/C compressor first run:
Engine at idle
Transmission in Park or Neutral
Do not cycle the ignition
Basic setting was performed for the flaps
Inside blower motor is switched on
Air vents fully open
Load management not active
"AC Compressor First Run-In" Steps:
Start engine and allow it to Idle.
Adapt flap end stops*as described above.
Select "Compressor Run In; Automatic Start" from the drop-down list.
[Go!]
It will show completed, but wait 120 sec (2 Min) and observe the flashing A/C button light on the HVAC panel.
After the Basic Settings has completed, the A/C light will quit flashing and the fault code will clear.
[Stop]
Note:*If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change "Driving time for compressor run in" from 120 -to- 120 and save it followed by repeating the entire procedure
Climatronic _-_-_-_-_-_-_-_-_-_-_-_-_-_-
Coding
Basic Setting
Note:*The basic setting needs to be performed, when the Climatronic control module (J255) or flap motor(s) have been replaced.
[Select]
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
[Done, Go Back]
Necessary when the Climatronic control module (J255) is replaced.
Engine at idle
Note:*If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change the Runtime (or Driving time) for "compressor run-in" basic setting from 120 -to- 120 and save it followed by repeating the procedure.
Manual heating + cooling -_-_-_-_-_-_-_-_-_-
Coding
This module does not support coding!
Basic Setting
The Manual Heating/Air Conditioning controller does not require a scan tool to perform the Basic Settings for the Activation of the A/C Compressor, please use the following instructions below.
Position the blower switch to the first or second speed
Position the air distribution control to 'Vent'
Position the interior temperature control to 'Cold', turn to the stop
Start the Vehicle's engine while in Park/Neutral
Simultaneously press/ hold the AC and Defrost buttons until the AC and recirculation buttons illuminate
Cycle the ignition and check for fault codes in the 08-Auto HVAC and proper HVAC system operation.
Special Notes
This procedure above, must be competed when:
The J301-Air conditioning system control unit is replaced.
The fault code*00898-005 will not clear.
http://wiki.ross-tech.com/wiki/index.php/B109E
Sent from my SM-N960U using Tapatalk
