Hi all
First off, apologies. I hoped this would be a solution to, rather than 'help' post considering the time I've spent on the issue.
I have a buzz/ vibration coming from the region of the driver's door/ around the steering wheel area (UK). '19 GTD
Audio clip here, taken accelerating out of a junction:
https://youtube.com/shorts/jcB7RoSXIF4?feature=share
After trawling the forums I have tried all the easy fixes that have been suggested:
Sunvisor/ trim around rear view mirror/ foam pads in trim gaps/ remove small door on the side of dash and poke around steering column & top of pedals/ Krytox door seals and felts/ push pull and prod everything within reach/ set soundaktor to eco/ feel if fuel line plastic cover is lose on top of wheel arch/ seatbelt on B pillar/ seat rails.
Then I went to the dealers, who agreed they could hear something. They said it was the engine mounts required tightening and all was now fixed... It definitely wasn't as the noise is still present. 3 additional visits to the dealers later and they can no longer hear the noise apparently (shocker).
The 'buzz', which sounds like plastic or metal vibrating against each other, presents itself once the car is warm (not in the first 5/10 mins of a cold morning). The warmer the ambient temperature, the more audible the buzz it seems. Heard when under hard acceleration and sometimes over rough road surfaces. Which leads me to think something is expanding with heat... accelerating with the door slightly open seems to stop the noise (or the wind noise is drowning it out)
So I'm putting this post here on the off chance something sounds familiar to one of you! Before I got to the dealers for the 5th time...
Cheers
Cheers
