MK7Boostedbliss
- nv
About a year later and I still have yet to do this haha. I really need a free weekend...
[emoji23][emoji23]
OK, so in my case I don't think this is the problem. At least not yet. I got the trim and pieces off (nice instructions btw) and taped up the hole and taped some padding in. Then just as I snapped the a pillar trim in I realized "oh I should have gone for a drive with everything disassembled FIRST". DUH.
So I tried it before putting the last two plastic bits back. It's still fucking there. Really pissing me off. Now it's too dark and I'm too annoyed to take all the trim back off. But tomorrow I'll take it back off and then drive and see what's what. If it's still doing it then, then I'll know that's not it.
Why must I be so stupid?
I de-rattled my STI, and one trick I learned was to use Permatex gasket maker in a tube. It is basically a soft silicone, that doesn't stick very well. It fills gaps, makes a nice jelly pad, and if you ever need to take that area apart it is no problem.
Thank you for this! Been hearing this sound since I had the car but couldn't find the source.
I have a buzzing a pillar aswell. Anyone else have any more tips for fixing this? It is most noticeable when the stereo is turned up. This means I can't enjoy my music.
I tried this fix today with no luck. My sounds is almost identical to the video as well.
Did OP only take apart the drivers side A-pillar?
Mine sounds like its coming from the passenger side pillar but I took that all apart and taped as much as I could but the sound is still there.![]()
I did both pillars. I used some small pieces of leftover sound insulation I had, not tape, so I'm not sure if tape is really going to fix this issue.
Gotcha. I just edited my original comment. I just couldn't get the A pillar removed where it meets the dash. The 3 clips were disengaged but the A pillar was just "hanging" still connected to the dash. And I could not remove the small pillar piece that holds the pin either.
Any tips for removing the A pillar completely once the clips are disengaged as well as the trim piece that holds the pin? I may have another go...
Thanks!
You just have to bend it a bit and pull it out. It will come out. As long as those Christmas tree shaped clips are out there's nothing physically connecting the trim piece to the car, its just slid down in there.
The other trim piece you just need to pull the pin and you can get it out if I recall correctly, but it's been a long time.
