6 speed DSG fluid replacement technique
Stackman1
South Carolina
For those that do not have the ability to measure the fluid temp, is there an engine temp that you can be reasonably sure equates to a DSG fluid temp between 35-45?
shortyb
Upstate SC
Felon Taxi,Dad Wagon
35-45C is not really that warm relative to engine temp and would say its between 140-170 on oil temp reading. I have never checked and thats just a guess. How about getting an OBD11? Its cheap and can do all sorts of other things with your car including things like DSG fluid temp ;).
Got Boost
Dover DE
2017 Golf R
My question is: why not just keep the drain port fill plug in the transmission with the ball valve closed after filling? (like this one: DAP # VAS6262 ) Once the transmission reaches the prescribed temperature you could open the ball valve and let the fluid drain. Once the fluid slows to a drip you could then swap it with the OEM drain plug and torque it down.
The only logical issues I can imagine with this are if the pressure in the transmission is high enough to possibly blow off the tubing from the fill plug but this seems unlikely since the DSG has an overflow vent. The second issue I could imagine is if there is a small window of opportunity between 35C and 45C temperatures where the fluid might not drain fast enough out through the drain port fill plug.
Don't take this too seriously, I'm just surprised the procedure is "try to be quick and not spill much" so of course I imagine myself bobbling the drain plug as all the fluid pours out :p
Thanks!
This is exactly what I did. Left the fill adapter in and ran the car on my lift until the trans came up to the prescribed temp, then unclamped the hose and let the excess drain back into the original bottle. After which I put the drain plug back in mess free.
Got Boost
Dover DE
2017 Golf R
I just did my service and the engine was up to temp long before the trans reached 35 deg Celsius.
shortyb
Upstate SC
Oil or coolant? We all know the "coolant gauge" gets to 12 o'clock pretty fast, but true oil temp takes much longer. Gauge gets a woody probably before you crawl under the car :D. Just get a damn OBD11 and take the guesswork out of it.
Got Boost
Dover DE
2017 Golf R
The temp requirement isn’t for the oil or the coolant, is for the transmission fluid. I used a my Snap On scanner which gave me the trans fluid temp, so no guess work and no need for OBD11.
It probably would have warmed up faster if I drove the car, however I still had my servicing adapter installed in the drain hole. So had to let it idle until it reached temp.
