6 speed DSG fluid replacement technique
goonie284
Chicago IL
2015 Golf R
Hey guys! I had a question about the DSG fluid replacement procedure technique, perhaps someone who has performed it can comment.
I see the procedure is to basically:
  1. overfill the transmission from the drain port,
  2. quickly swap the drain port fill plug with the OEM drain plug, and try not to spill too much fluid in the process.
  3. Next you warm up the transmission fluid to the prescribed temperature (35C-45C) and then remove the OEM drain plug to let the excess fluid escape.
My question is: why not just keep the drain port fill plug in the transmission with the ball valve closed after filling? (like this one: DAP # VAS6262 ) Once the transmission reaches the prescribed temperature you could open the ball valve and let the fluid drain. Once the fluid slows to a drip you could then swap it with the OEM drain plug and torque it down.
The only logical issues I can imagine with this are if the pressure in the transmission is high enough to possibly blow off the tubing from the fill plug but this seems unlikely since the DSG has an overflow vent. The second issue I could imagine is if there is a small window of opportunity between 35C and 45C temperatures where the fluid might not drain fast enough out through the drain port fill plug.
Don't take this too seriously, I'm just surprised the procedure is "try to be quick and not spill much" so of course I imagine myself bobbling the drain plug as all the fluid pours out :p
Thanks!
Keehs360
Denver
Mk7.5
Lots of tricks I’ve learned
best one is filling the tranny from the filter. Just gotta make sure you don’t make a mess.
tigeo
I just did this service using that tool and the bottom fill/overfill/drain @ temp to set the proper level method a few mos. ago which is how you are supposed to do this to ensure it's filled to the correct level - I get some go through the top but that is predicated on knowing exactly how much fluid came out and to me, doing it from the bottom isn't that hard and I have heard that it fills v. slowly from the top; the bottom fill is quick but you do need to poke holes in the bottles to increase the flow to the trans. It's not really that messy if you are quick to remove the tool/replace the drain plug. If you left the tool in the drain plug, the tube is long so it's not going to drain quite like you are thinking as if you had the tool with the ball-valve at the trans and removed the tube. Also, you won't be able to accurately gauge when it's time to replace the drain pug b/c you will be getting some spurts etc. as it reaches the correct level. Honestly, this isn't that difficult to do the way the DIY videos show it and it seems to be the standard way so I just stuck with it.
Keehs360
Denver
Mk7.5
This is definitely the best way of doing it vs filling through the oil filter hole.
Filling from the top makes a tiny mess. And getting your hand in there to clean it perfectly is a pain.
shortyb
Upstate SC
Felon Taxi
9 DSG fluid changes between my 2 cars and friends. All top fill through filter tube, never had any issues. Use this funnel with a bungie to hold it upright. Not really slow filling (no holes punched in bottles), about half a beer per container timewise ;). Overfill slightly to 4.8 or 4.9 qts then do remainder of procedure as outlined. You don't have to be THAT quick to put plug back in once it slows to a drip and no mess swapping over tool/hose/drain plug etc. Takes me about an hour and a half start to finish and thats with R/R-ing the battery/tray etc. Easy peasy.
Or get even easier. Drain, fill with 4.7 qts through top when changing filter, button up and go. As someone once said, it's just a gloriifed oil change and 4.7 is damn close enough. Do NOT agonize over something as simple as this, save that for why you picked the DSG over a manual in the first place 😁.
Keehs360
Denver
Mk7.5
Just put that funnel in my cart for Friday. That’s a good funnel. Shit I was using made a mess LOL
CarolinaGTIMk7
jacksonville NC
2016 GTI SE
Will be doing my first DSG service this week. What steps need to be done after fluid change? Is it just letting the trans warm up, engage each gear and reverse and is THAT IT ?? Am a GTI newbee and just bought a 2016 with 40K miles.
gixxerfool
New Jersey
2016 Golf R
I am pretty sure the trans temp needs to be in a range, I am not 100% though. Then remove the large drain plug on the bottom and allow the excess to drain out. Once it becomes a drip, reinstall the drain plug and off you go.
Try this:
tigeo
Nothing - change the fluid/filter, end. I've done it, it's simple.
tigeo
Try this:
The fluid temp is only to set the level after the drain/fill/filter change. You set the final level at the recommended temp.
