3D Printer & C.A.D. Thread
jawndropper
Tysons, VA
2017 GTI Sport
Is the logo raised?
In Tinkercad you would set your drawing plane to the surface that the letters come out of. Drop a rectangle/square big enough to cover the logo and make it a hole. This will delete all objects in the square that are flush and higher then the plane.
Turned out good 👍
i used fusion 360, the logo is recessed into the plate. I still can push/pull the logo but when I zero it out the border is still there, I cant seem to actually delete the logo. 🤷‍♂️
GolNat
Delaware
13 GTI & 98 Prelude
Ohh. Can you do what I said but instead of a hole add a solid square? That might fill in the logo. Or maybe raise the overall height of the part by .1-.2mm to cover the border?
I’d like to try Fusion 360. Tinkercad has one things missing like filet that I would like.
NoGodGetOverIt
NC
2017 GTI SE/DSG
Coinslot cover is done. Still not perfect, but I am pretty happy with this. I wanted to make a second blank version but I cant figure out how to remove the logo now lol. I uploaded it to thingiverse but new accounts are restricted for 24 hours. I will post the link here tomorrow.
That's awesome! I've been toying around with the idea of making a mount for my BMS pedal tuner that would sit in those slots. This could be a perfect base for it!
GolNat
Delaware
13 GTI & 98 Prelude
GolNat
Delaware
13 GTI & 98 Prelude
Print a radius gauge so you can measure and get a closer match.
GolNat
Delaware
13 GTI & 98 Prelude
Prusa slicer and the MK3 make color changing so much easier. I tried slicing a file with Prusa and running it on my Elegoo but it didn’t like it. Probably need to modify the G-Code.
Finally made my sandpaper holder. Was a 8-9 hour print on the Neptune 2S. The time frame was way off on Cura so I need to look into that. Said something like 10-11 hours.
Made some more of these too
AzteCypher
Austin, TX
Mk7 Golf R
Roald
Ohio
GTI mk 7 2017
I just came across the ability to import a photo to Fusion and literally just trace it. I'm not sure how well I'll do with that but I'm going to give that a shot. I considered a radius gauge but I need it for the top edge its several inches wide and is just an arc.
I'm sure there's a pro way to do it, but I'm only just okay at Fusion anyways
AzteCypher
Austin, TX
Mk7 Golf R
I ended up using my photo scanner to scan in an image of a game cartridge I was trying to repair. I then traced what I wanted to 3D print, turned into an SVG, imported it into Tinkercad, and out came the STL. Worked pretty good actually.
dtfd
Massachusetts
MK7.5 GTI
How did you make it 3 dimensional? Or did the scanner just grab the general height/width and you added depth in tinkercad?
Corprin
Magrathea
A car
Been on hiatus.
Printing a socket to change the air spring in my MTB fork. Decided I’d flex my speeds.
GolNat
Delaware
13 GTI & 98 Prelude
Damn that’s Stage 3 for sure!!
PETG for the socket?
